Dear Sir,
Please let me describe my problem: an offshore barge is permanently moored along the river bank by using 3 piles of which the bottom ends are fixed on the seabed, the top end are connected to the barge, and what I want to know is the reaction force at the 3 Barge-Pile connections under a certain circumstance.
3 bodies are modeled in the dat.file, one is barge itself, second is three piles, and the last is seabed which is intended to show as a picture purpose, no force attracted. And two types of GSPR connector are applied to barge-pile connection and pile-seabed connection respectively, and I use REST(restraint) to fix the 3 points of the seabed body which are also connected to the bottom of the 3 piles by using the GSPRs. Then I thought the entire model had be well restrained. But When I check the log file, the reaction force of all the connectors are 0, even when I see the graphic animation, the whole model is moving along as the sea(wave) is approaching.
I have no idea where the problem takes place and I have tried dozens of time, still fail to solve to the problem. So I come here and beg somebody to give me hand and help out the jam.
Thanks and Regards
Xintong
