Hi
How do you connect lines to other lines in MOSES? For instance if I have a barge with two bridles from the corners of the bow than then connect to a hawser by using, for instance a mooring ring. The mooring ring is not really important here.
So the question is about connecting multiple lines to one.
Can you please provide an example? A typical system would be the one sketched below. That would be great,
Fabrizio
What you show as "buoy" and "ring" need to be modeled as bodies.
sir please tell what is to be done in this case like:
I have been given a single leg mooring buoy such that buoy has 4 chains coming down together and get connected to wire rope straight away connecting to the anchor.please help to tell me the way connect these five mooring lines together.
Hello Devansh,
There are examples on how to connect bodies. There are examples on how to connect bodies to ground via mooring lines. ONe such sample is the calm files.
Please see the calm files in the following directory.
C:\Program Files\Bentley\Engineering\MOSES CONNECT Edition V11\hdesk\runs\samples\mooring
Georgina Maldonado
Ma'am i saw it but my figure is coming out like this.can you tell whats wrong going on in my code.
nbuoy_pgen_8mdepth_1.1mowc_vignesh.dat
&device -primary screen -oecho no $-f_cd_tube 0.6 &dimen -dimen Meters m-tons ¶meter -m_dist 1.5 $ $********************************************* GEN. DATABASE $ INMODEL &title nbuoy modeling &equi $&instate -cond 0.75 0 0 &stat medit &describe body nplate *M1 .25 .25 -6 *M2 -.25 .25 -6 *M3 -.25 -.25 -6 *M4 .25 -.25 -6 ~niotrope b_cat 25 -len 20 -wtpl 0.005 -emodulus 89631.88 -buoydia 0 -c_sn rope -depan 16 -b_tension 93 CONNECTOR H -ANCHOR 45 15 ~niotrope *M6 &describe body nbuoy *cdeck 0 0 1.8 *cleara 1.5 0 1.8 *clearb 0 1.5 1.8 *clearc -1.5 0 1.8 *cleard 0 -1.5 1.8 *MLA 1.06 1.06 0.5 *MLB -1.06 1.06 0.5 *MLC -1.06 -1.06 0.5 *MLD 1.06 -1.06 0.5 ~niotchain h_cat 25 -len 8 -wtpl 0.012 -emodulus 64000 -buoydia 0 -c_sn chain -b_tension 36 CONNECTOR CN1 ~niotchain *M1 *MLA CONNECTOR CN2 ~niotchain *M2 *MLB CONNECTOR CN3 ~niotchain *M3 *MLC CONNECTOR CN4 ~niotchain *M4 *MLD end_medit &dimen -dimen Meters kn &status Force $&connector @ -a_tension 1 &stat &status f_connector &status Force $&equi $&stat $&status f_connector $&status Force $ CONN_DESIGN TABLE ml1 REPORT end MOVE nbuoy 0 REPORT end end_CONN $ &picture top &picture port &picture front &stat &status f_connector &status Force $ hydro g_pressure -period 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 6.5 7 8 9 10 11 12 13 14 15 16 17 18 19 20 e_total end Freq_resp rao -heading 0 equ_sum fr_point plot 2 3 5 7 -rax 9 11 13 -n report end end $&data curves c_profile loopcur 0.0 1.00 \ 20.0 0.33 \ &data env env niot -sea jonswap 0 0.8 4.4 3.3 -time 1000 0.01 -wind 45 0 -w_profile abs -current 0.6 0 $-ramp 50 -use_mean no end_&data &env niot $&instate -loc -10 0 -0.93 0 0 0 &stat &stat force &stat f_connec &equi -iter 400 &stat &status f_connector &status Force tdom prcpost cf_magni plot 1 2 4 6 8 -n report end
Before you start any analysis you should have a good model. The minimal requirement of a good model is that the log file report 0 errors when reading the model. The data file you sent does not meat the minimum requirement.
Please fix the body nplate definition of ~moor.
