Hi friends,
IN SACS For member whether we can give glopal and local offset both ex for bracing i want local offset in 'X' direction and glopal offset in z direction,Please advice me
C.karthikeyan,
The member offsets can only be set in either global or local offsets so you will have to convert the one of the offsets to the other and then add them together. You can convert offsets easily using the "convert selected offsets to X coordinates" commands in the Member Offsets dialog.
Geoff
Thanks ,
C.karthikeyan
