Hi guys, Im doing a canoe and I've modelled it. Im having problem with stability analysis. I dont know the steps to be followed in it. Please guide and assist me through it. I attached my model here. Also tell me how to check whether my model is fine. Maximum displacement of 73 kg. My scenario is that the canoe must float on still water with self weight and must carry 1 person of 100 kg weight. Kindly help me
Ashwath S
You can do a simple analysis in the Data | Calculate Hydrostatics dialog in Modeler -- that will give you the displacement at the DWL you have specified in the Frame of Reference dialog (data menu)
For more comprehensive stability analysis in Stability, please have a look here:
https://www.youtube.com/playlist?list=PLX3HK9S8pbdiZnDXqFyadIeHNSqkr7Byt
