I am running a transportation analysis and am using weight cards. I have included the "INCWGT" card with only one weight from my geometry input file.
It does not include this weight in the load summation. I've run these before and they worked fine, now there seems to be an issue.
Here is the tow input file, what am I doing wrong:
TOWOPT MNEC MP WPRC -1.5YXZ 1.10 DS INCWGT 0001 MOTION8000 G END
I'm using 5.7.1 V8i Select Series 4
Michael,
The above tow input file should be fine as long as you have defined your model input file correctly. It is difficult to say what may be wrong without looking at the model file and run file associated with this analysis, but there are a few things I would check:
If you are still having problems with the tow analysis, I would recommend that you submit a service request and attach the tow input file, the sacs model file and the analysis run file so that a Bentley technical service representative can take a closer look at the issue.
Geoff
