I am getting following error while running "post-processing" spectral fatigue analysis:
"*** ERROR - MEMBER 2264-2265 NOT IN ORDER ON 8 POSTFILE
IT SHOULD PRECEDE - MEMBER 6842-6843
*** ERROR - MEMBER 9546-9547 NOT IN ORDER ON 8 POSTFILE
IT SHOULD PRECEDE - MEMBER 9842-9843
*** ERROR - MEMBER 9662-9663 NOT IN ORDER ON 8 POSTFILE
IT SHOULD PRECEDE - MEMBER 9844-9845
*** ERROR - MEMBER 6344-6345 NOT IN ORDER ON 8 POSTFILE
IT SHOULD PRECEDE - MEMBER 9762-9763
*** ERROR - MEMBER 6332-6333 NOT IN ORDER ON 8 POSTFILE
IT SHOULD PRECEDE - MEMBER 6920-6921
*** ERROR - MEMBER DATA ON POSTFILES OUT OF ORDER"
Any help would be highly appreciated.
Irfan,
Are you using multiple common solution files which are dissimilar? It appears that SACS is looking for members that don't exist in your common solution file.
If you would like, you can submit a service request and attach the files so that a technical support representative can take a closer look at the problem.
Geoff
