hi,
I am using SACS 5.7.0.1 version and while running the static analyses it shows system error and in the psvdb file the member forces and design details are not available.
Please solve this issue ASAP.
Hi Karthikeyan, We need to check your sacs input files to find the cause of error. If you would like, you can submit a service request and attach the files so that our technical support team can take a closer look at your problem. Kevin
