Hello, please can someone help.
I'm trying to render the wave grid in Maxsurf motions however when I follow the manual steps and create the animations I do not get the rendered waves only the grid lines. Advice and guidance would be much appreciated.
Hi Matthew,
I either couldn't replicate your error, or didn't understand the error you were having.
I've used Steps Recorder (psr) to record the process I've gone through to animate motions on our sample file. Perhaps you can spot something that I've done differently to you.
To view the file, unzip it and open it in a web browser. If you are still having problems, can you send me some screenshot to clarify the problem.
James
MotionsWaveSurface.zip
James.
Thank you for your response. Unfortunately I can't view your zip file but thank you anyway. I can run animations as per the image below but I cannot get the wave grid to appear as solid water. The manual shows that you can do this however it doesn't explain which buttons to press. Hope this makes sense
Hi Matthew -- can you tell me what graphics card you have in your system and which operating system, do you have any rendering acceleration turned on? The rendering is behaving correctly on the 2 machines I have available to test on here. Could you also confirm the version of Motions that you are using (most of this information can be found in the Motions Help|About dialog if you click on the "Sys Info" button)
Pat
Image below is from Motions 21.02.00.05 64bit running on Windows10
please refer to the wiki post here: communities.bentley.com/.../rendering-problems-with-intel-graphics-cards
