Problem running spreader model for Lifting Analysis in MOSES
I currently working on my undergraduate final project which is simulation to jacket lifting, I used the vessel from Ultramarine library to generate tanker which will lift the jacket. So, far I tried to insert model from library but the model vessel can't be read by the system. (I inserted the log file data and other data also)
>inmodel
 Defining Vessel with:
    C:/Program Files/Bentley/Engineering/MOSES 7.10  \
       V8i//hdesk/tools/vessels/cbarges/amt_carr.dat
                   *** ERROR:  -6.92500 Is Not a Valid Name
Then I tried to add .dat file to make it readable.
$   READ BARGE MODEL
&insert ./barge.dat
jacket installation.rar
The problem solved, I also made the same method for the spreader model, but when I inserted it becomes all unreadable. It said that spreader file isn't defined yet. The error comes early, now the vessel isn't readable, (it seems like vessel and spreader file are read as one package file).
Second, I had finished all the datas required to run analysis. How it should be if I want to get the structural analysis also?
I really need your help. Many thanks.
