Hi! If I insert a pressure database in MOSES (using &insert), the command window echoes the content of the file. I don't think it used to be like this (I use &device -oecho no). Is there a new &device setting to avoid this?
Lars Rune
Hi Lars,
Nice to hear from you.
There is not a way to suppress the echo when you read in the database in the command file. If you read the database in the data file as part of "inmodel" then it obeys the "&device -oecho n" setting.
I hope this helps.
