Should I use the option -API_TDRAG YES -AF_ENVIRONMENT YES in launch analysis?
With these two options YES, the clearence between jacket and mudline is much smaller than that when they are set NO.
So , which should I choose and why?
Hello Ju Peng,
The value to use for these options is a project decision. User support is here to provide clarification on what is programmed. I can tell you that the values of "no" for both options is what is the default values. The default values have been accepted by many projects.
Georgina Maldonado
