Barge launch stability
The standard commands to calculate wind heeling arm are:
hstatic
rarm inc num -wind
report
end
The above makes the assumption that you have positioned the cargo and the barge system at the condition (draft, roll, trim) you are interested in.
I think there is more to your question, however, I do not want to infer.
I hope the above helps.
Georgina Maldonado
MOSES Product Manager
How about equation/formula to determine wind heeling arm that used in moses ?
Hi Muhammad,
The equations are those found in the regulations. You can designate which regulation to use with the "&env" command. There is already a post about this. Please see the following link.
https://communities.bentley.com/products/offshore/w/wiki/29475/wind-moment-calculation-for-use-in-stability
based on the rule that the heeling arm is vertical distance, in meters (feet), from the center of A to the center of the underwater lateral area or approximately to the one-half draft point, so if I have barge 14 ft (depth)) and 7 ft (draft) that the heeling arm is 7 ft, but the results is different from the moses results in the picture above. The heeling arm is 2.59 ft (moses results smaller than the rule)
Hello Muhammad,
I do not know how you have modeled the wind area. And I have not seen your hand calculations. It is difficult for me to respond.
How about you show the results of:
&summary
compart_sum piece
That will at lest show if the area is being defined by panels.
If you would like to open a service ticket please use the Connection Client that was installed with the software.
