I am a new user to MOSES. I have observed a webinars in which MOSES Hull Modelling & Hydrostatics & Motion Analysis module shows SACS Module as a part of MOSES. Generally whats the best way of modelling a vessel in MOSES. Through SACS Modeller and importing into MOSES ? or directly modelling in MOSES. The following path of webinar video had SACS Modules as MOSES Modelling tools
pages.info.bentley.com/.../
Hi Siddharth,
Thank you for your interest.
Your question is not easy to answer. It depends on the vessel and your background. I have been modeling vessels in MOSES since 1980's and I am quite happy opening the editor and typing in numbers to generate lines plans. I do this mostly for monohull ship shapes. With today's GUI tools many people would find that excessive labor.
You mentioned you saw some videos showing SACS Modeller. This is the same as MOSES Hull Modeller. MOSES Hull Modeler should be available with your MOSES installation. This application in general is very CAD like. I would use it for all shapes (monohull, semi-subersibles, jackup, GBS).
When I talk with other users I also frequently hear people using Rhino. I have seen people model all shapes in Rhino.I have not run Rhino, but it appears to be very popular.
I this helps.
Georgina Maldonado
Hi Gina,
I was wondering if you can help me with this. Im currently modelling a tanker FSU using moses strip method. however, the surface seem to be problematic at the bulb section and fore. Also tried the 3ddif method by it doesn't go as planned. I have no idea on how to tell MOSES to cut the fwd into desired shape profile. Appreciate if you can guide me through this.
I attached my vessel data file (strip and 3ddiff) for your reference. Thanks
Rgds,
Nas.
tanker02.dat
$********************************************* set data $ &dimen -save -dimen metres m-tons &set vlength = 243.00 &set vbeam = 45.00 &set vdepth = 25.00 &set vname = nauticamuar &set lwtf =132027 $ $********************************************* macro for plotting $ ¯o su_show names &if %plot &then &select :n -select %names &if %demo &then &device -g_default screen &subtitle %subt picture iso &picture iso -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &subtitle %subt picture top &picture top -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &subtitle %subt picture bow &picture bow -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &subtitle %subt picture stab &picture stab -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &else &device -g_default device &subtitle %subt picture iso &picture iso -parent :n &subtitle %subt picture top &picture top -parent :n &subtitle %subt picture bow &picture bow -parent :n &subtitle %subt picture stab &picture stab -parent :n &endif &endmacro $ $********************************************* generate &surface $ $********************************************* define body $ $*cgfsumuar 119.166 0 11.724 $&weight *cgfsumuar %lwrf 0.29*%vbeam% 0.32*%vlength% 0.32*%vlength% $ $********************************************* dimensions $ $ format (-locat translate x,y,z (rot-x roll)(rot-y pitch) (rot-z yaw)*********** $ $****pgen cabin -perm 0 -diftype none $$$$$$-locat "(translate)x coordi=6.5m" "(translate)y+ve@port= 0m" (translate)(depth-base)=13.01m $$$$$$(rotate@x-axis-ccw)=0deg (rotate@y-axis)=-90 (rotate@z-axis)=0 %win_cur $***after -locat the distance will be zero after locate x-translate!!********* $***-locat translate from midpoint surface!!********************************* $**pgen = origin,height.witdh*************** $ $ $______________create superstructure________________________ $ $ $************************************************************** block one -loc 149 0 16.95 0 0 0 plane 0 17 -rect 0 14.5 20.41 end $ block two -loc 149 0 31.45 0 0 0 plane 0 4 -rect 0 1.63 30 end $ block three -loc 149 0 31.45 0 0 0 plane 0 16 -rect 0 4 16 end $ block four -loc 149 0 16.95 0 0 0 plane 0 29.5 -rect 0 10 14.6 end $ block five -loc 149 0 16.95 0 0 0 plane 0 29.5 -rect 0 14 10 end $ $ $ $**************************************** bulbous bow $ &surface block bow plane 0.0000 -cart 0 0.4 plane 0.5000 -cart 0 20.431 2.002 21.079 plane 2.5000 -cart 0 1.749 0.338 2.45 0.67 3.267 0.895 4.144 \ 0.932 5.065 0.73 6.004 0 6.9 0 17.761 1.173 18.476 \ 1.708 18.959 3.044 19.989 4.289 21.079 plane 5.0000 -cart 0 1.749 0.338 2.45 0.67 3.267 0.895 4.144 \ 0.932 5.065 0.73 6.004 0 6.9 0 17.761 1.173 18.476 \ 1.708 18.959 3.044 19.989 4.289 21.079 end $****************************************** hull body block mhull plane 5.0000 -cart 0 0.635 0.841 1.51 1.144 2.223 1.393 3.033 1.579 3.894 \ 1.687 4.759 1.708 5.587 1.639 6.348 1.487 7.019 1.266 7.588 \ 0 8.414 0 13.788 0 14.326 0.255 14.884 0.545 15.442 \ 1.117 16.226 1.727 16.865 3.717 18.802 4.288 19.295 6.285 21.079 plane 7.9342 -cart 0 0.208 0.516 0.491 1.215 1.47 1.473 2.177 1.697 2.962 \ 1.878 3.795 2.001 4.629 2.055 5.43 2.035 6.171 1.942 6.837 \ 1.783 7.422 1.57 7.933 1.051 8.783 0.609 9.52 0.359 10.327 \ 0.313 11.267 0.456 12.272 0.6 12.779 0.798 13.29 1.11 13.835 \ 1.497 14.417 2.004 15.078 2.745 15.916 3.867 17.059 5.621 18.695 \ 8.218 21.079 plane 10.0000 -cart 0 0.129 0.51 0.333 1.008 0.903 1.293 1.473 1.554 2.162 1.785 2.934 \ 1.973 3.749 2.106 4.565 2.174 5.349 2.174 6.077 2.109 6.735 \ 1.987 7.318 1.822 7.832 1.442 8.719 1.117 9.523 0.953 10.338 \ 1.004 11.204 1.276 12.121 1.804 13.111 2.159 13.648 2.585 14.232 \ 3.13 14.908 3.727 15.571 5.038 16.943 6.769 18.633 9.391 21.079 plane 12.0000 -cart 0 0.097 0.728 0.453 1.329 1.428 1.597 2.094 1.839 2.839 2.044 3.627 \ 2.202 4.419 2.303 5.185 2.346 5.902 2.333 6.556 2.272 7.144 2.175 7.669 \ 1.95 8.589 1.791 9.422 1.788 10.245 1.97 11.094 2.336 11.986 \ 2.903 12.949 3.263 13.479 3.687 14.062 4.225 14.747 4.98 15.626 \ 6.117 16.838 7.358 18.068 7.843 18.574 10.333 21.079 plane 15.8685 -cart 0 0.035 0.749 0.362 1.424 1.263 1.739 1.88 2.036 2.573 2.309 3.31 \ 2.548 4.058 2.75 4.79 2.913 5.485 3.039 6.132 3.133 6.725 \ 3.205 7.266 3.326 8.228 3.48 9.094 3.716 9.92 4.052 10.745 \ 4.497 11.605 5.068 12.559 5.409 13.097 5.799 13.699 6.29 14.417 \ 6.981 15.349 8.02 16.634 9.599 18.463 11.408 20.468 11.926 21.079 plane 23.8027 -cart 0 0.002 0.603 0.06 1.159 0.239 1.681 0.538 2.659 1.471 3.125 2.071 \ 3.576 2.725 4.01 3.403 4.426 4.077 4.823 4.728 5.199 5.341 \ 5.554 5.909 5.887 6.43 6.492 7.359 7.026 8.182 7.51 8.957 \ 7.973 9.74 8.448 10.595 8.962 11.607 9.24 12.203 9.542 12.887 \ 9.903 13.712 10.399 14.777 11.139 16.226 12.257 18.247 13.903 21.079 plane 31.7369 -cart 0 0 0.839 0.037 1.673 0.16 2.478 0.383 3.236 0.709 3.937 1.134 \ 4.577 1.641 5.161 2.207 5.7 2.802 6.203 3.4 6.677 3.982 7.126 4.532 \ 7.554 5.045 8.342 5.954 9.03 6.746 9.614 7.48 10.118 8.225 \ 10.58 9.058 11.037 10.067 11.272 10.667 11.517 11.347 11.774 12.129 \ 12.068 13.066 12.437 14.26 12.943 15.856 13.66 18.049 14.672 21.079 plane 39.6711 -cart 0 0 1.029 0.021 2.165 0.1 3.306 0.256 4.374 0.498 5.322 0.826 \ 6.129 1.23 6.803 1.69 7.372 2.181 7.865 2.682 8.708 3.645 \ 9.443 4.502 10.095 5.252 10.654 5.942 11.129 6.639 11.543 7.429 \ 11.933 8.409 12.129 8.999 12.332 9.67 12.547 10.431 12.777 11.302 \ 13.031 12.338 13.32 13.647 13.66 15.39 14.068 17.778 14.557 21.079 \ plane 47.6054 -cart 0 0 1.195 0.01 2.628 0.056 4.107 0.155 5.488 0.319 6.681 0.549 \ 7.643 0.84 8.387 1.18 8.962 1.551 9.79 2.321 10.408 3.061 10.941 3.734 \ 11.404 4.352 11.795 4.964 12.128 5.651 12.424 6.52 12.569 7.054 \ 12.717 7.671 12.872 8.379 13.041 9.187 13.227 10.113 13.431 11.223 \ 13.646 12.647 13.862 14.58 14.06 17.281 14.216 21.079 plane 55.540 -cart 0.000 0.000 1.341 0.004 3.024 0.028 4.784 0.085 6.424 0.184 7.818 0.326 \ 8.910 0.512 9.714 0.735 10.298 0.986 11.053 1.535 11.553 2.099 11.968 2.642 \ 12.317 3.156 12.601 3.675 12.827 4.279 13.019 5.080 13.111 5.591 13.205 6.191 \ 13.304 6.891 13.414 7.701 13.537 8.642 13.672 9.797 13.809 11.330 13.934 13.489 \ 14.024 16.602 14.051 21.079 plane 63.474 -cart 0.000 0.000 1.445 0.002 3.289 0.015 5.224 0.047 7.023 0.104 8.540 0.189 \ 9.712 0.303 10.557 0.446 11.150 0.612 11.873 1.003 12.498 1.666 12.953 2.324 \ 13.252 3.015 13.385 3.628 13.494 4.501 13.548 5.071 13.605 5.746 13.668 6.538 \ 13.740 7.472 13.818 8.648 13.897 10.257 13.966 12.593 14.011 16.041 14.010 21.079 plane 71.4080 -cart 0.0000 0.0000 1.5155 0.0011 3.4544 0.0081 5.4881 0.0262 7.3747 0.0595 \ 8.9596 0.1111 10.1759 0.1834 11.0434 0.2776 11.6434 0.3940 12.0577 0.5318 \ 12.3518 0.6891 12.5756 0.8630 12.7627 1.0493 12.9308 1.2432 13.0833 1.4391 \ 13.2182 1.6333 13.3342 1.8256 13.4313 2.0196 13.5102 2.2222 13.5730 2.4441 \ 13.6227 2.6994 13.6628 3.0043 13.6965 3.3746 13.7269 3.8253 13.7564 4.3708 \13.7875 5.0247 \ 13.8219 5.7998 13.8608 6.7251 13.9034 7.9086 13.9461 9.5641 13.9830 12.0108 \ 14.0050 15.6731 14.0003 21.0790 plane 79.3423 -cart 0.0000 0.0000 1.5712 0.0005 3.5771 0.0036 5.6770 0.0124 7.6210 0.0296 \ 9.2496 0.0583 10.4942 0.1016 11.3760 0.1627 11.9801 0.2444 12.3914 0.3481 \ 12.6784 0.4736 12.8928 0.6189 13.0696 0.7804 13.2274 0.9529 13.3692 1.1299 13.4928 1.3068 \ 13.5969 1.4824 13.6812 1.6597 13.7466 1.8452 13.7952 2.0492 13.8301 2.2856 \ 13.8550 2.5707 13.8733 2.9207 13.8877 3.3511 13.9005 3.8772 13.9133 4.5138 \ 13.9274 5.2752 13.9433 6.1929 13.9607 7.3823 13.9781 9.0705 13.9931 11.5967 14.0020 15.4120 \ 14.0000 21.0790 plane 87.2765 -cart \ 0.0000 0.0000 \ 1.6057 0.0002 \ 3.6395 0.0021 \ 5.7611 0.0076 \ 7.7207 0.0192 \ 9.3598 0.0399 \ 10.6101 0.0731 \ 11.4941 0.1227 \ 12.0977 0.1924 \ 12.5069 0.2843 \ 12.7908 0.3988 \ 13.0017 0.5343 \ 13.1749 0.6874 \ 13.3289 0.8527 \ 13.4669 1.0236 \ 13.5866 1.1951 \ 13.6866 1.3658 \ 13.7665 1.5383 \ 13.8273 1.7187 \ 13.8711 1.9170 \ 13.9009 2.1470 \ 13.9207 2.4245 \ 13.9337 2.7659 \ 13.9427 3.1870 \ 13.9496 3.7036 \ 13.9562 4.3314 \ 13.9633 5.0859 \ 13.9714 6.0001 \ 13.9801 7.1925 \ 13.9889 8.8945 \ 13.9965 11.4515 \ 14.0010 15.3222 \ 14.0000 21.0790 plane 95.2107 -cart \ 0.0000 0.0000 \ 1.6373 0.0001 \ 3.6945 0.0009 \ 5.8326 0.0038 \ 7.8033 0.0111 \ 9.4490 0.0255 \ 10.7029 0.0507 \ 11.5879 0.0911 \ 12.1910 0.1511 \ 12.5985 0.2334 \ 12.8801 0.3389 \ 13.0883 0.4664 \ 13.2587 0.6125 \ 13.4099 0.7720 \ 13.5450 0.9382 \ 13.6617 1.1057 \ 13.7584 1.2731 \ 13.8348 1.4425 \ 13.8919 1.6198 \ 13.9317 1.8146 \ 13.9576 2.0402 \ 13.9732 2.3123 \ 13.9820 2.6469 \ 13.9865 3.0603 \ 13.9889 3.5687 \ 13.9905 4.1885 \ 13.9920 4.9364 \ 13.9938 5.8468 \ 13.9957 7.0407 \ 13.9976 8.7531 \ 13.9992 11.3343 \ 14.0002 15.2495 \ 14.0000 21.0790 plane 103.1449 -cart \ 0.0000 0.0000 \ 1.6604 0.0000 \ 3.7275 0.0006 \ 5.8674 0.0031 \ 7.8356 0.0094 \ 9.4774 0.0224 \ 10.7276 0.0459 \ 11.6100 0.0842 \ 12.2111 0.1418 \ 12.6173 0.2217 \ 12.8980 0.3248 \ 13.1054 0.4501 \ 13.2752 0.5946 \ 13.4259 0.7531 \ 13.5604 0.9192 \ 13.6764 1.0876 \ 13.7725 1.2569 \ 13.8483 1.4290 \ 13.9046 1.6095 \ 13.9437 1.8074 \ 13.9688 2.0354 \ 13.9836 2.3084 \ 13.9915 2.6422 \ 13.9952 3.0529 \ 13.9966 3.5569 \ 13.9972 4.1714 \ 13.9977 4.9137 \ 13.9982 5.8196 \ 13.9988 7.0111 \ 13.9993 8.7243 \ 13.9998 11.3102 \ 14.0001 15.2348 \ 14.0000 21.0790 plane 111.0792 -cart \ 0.0000 0.0000 \ 1.6771 0.0004 \ 3.7475 0.0019 \ 5.8832 0.0053 \ 7.8441 0.0124 \ 9.4785 0.0258 \ 10.7230 0.0491 \ 11.6020 0.0866 \ 12.2015 0.1429 \ 12.6073 0.2209 \ 12.8883 0.3220 \ 13.0965 0.4453 \ 13.2672 0.5882 \ 13.4187 0.7461 \ 13.5541 0.9131 \ 13.6710 1.0844 \ 13.7679 1.2586 \ 13.8445 1.4375 \ 13.9016 1.6261 \ 13.9414 1.8326 \ 13.9672 2.0685 \ 13.9826 2.3477 \ 13.9911 2.6851 \ 13.9953 3.0962 \ 13.9972 3.5975 \ 13.9981 4.2064 \ 13.9987 4.9409 \ 13.9992 5.8380 \ 13.9996 7.0208 \ 13.9998 8.7265 \ 13.9999 11.3075 \ 14.0000 15.2309 \ 14.0000 21.0790 plane 119.0134 -cart \ 0.0000 0.0000 \ 1.6747 0.0033 \ 3.7229 0.0117 \ 5.8278 0.0238 \ 7.7580 0.0397 \ 9.3675 0.0608 \ 10.5959 0.0898 \ 11.4673 0.1306 \ 12.0660 0.1879 \ 12.4755 0.2651 \ 12.7629 0.3637 \ 12.9789 0.4838 \ 13.1578 0.6235 \ 13.3176 0.7794 \ 13.4611 0.9467 \ 13.5860 1.1217 \ 13.6908 1.3033 \ 13.7753 1.4930 \ 13.8402 1.6951 \ 13.8877 1.9166 \ 13.9210 2.1672 \ 13.9438 2.4584 \ 13.9592 2.8037 \ 13.9699 3.2175 \ 13.9777 3.7159 \ 13.9839 4.3161 \ 13.9890 5.0369 \ 13.9932 5.9164 \ 13.9963 7.0791 \ 13.9983 8.7644 \ 13.9995 11.3269 \ 13.9999 15.2366 \ 14.0000 21.0790 plane 126.9476 -cart \ 0.0000 0.0000 \ 1.6093 0.0166 \ 3.5363 0.0572 \ 5.5019 0.1105 \ 7.3030 0.1686 \ 8.8123 0.2271 \ 9.9779 0.2852 \ 10.8227 0.3457 \ 11.4224 0.4137 \ 11.8514 0.4937 \ 12.1697 0.5888 \ 12.4226 0.7007 \ 12.6405 0.8298 \ 12.8391 0.9750 \ 13.0209 1.1342 \ 13.1838 1.3057 \ 13.3264 1.4895 \ 13.4483 1.6871 \ 13.5505 1.9020 \ 13.6347 2.1388 \ 13.7039 2.4044 \ 13.7613 2.7069 \ 13.8097 3.0569 \ 13.8511 3.4674 \ 13.8870 3.9533 \ 13.9180 4.5321 \ 13.9443 5.2234 \ 13.9654 6.0672 \ 13.9810 7.1906 \ 13.9914 8.8365 \ 13.9973 11.3637 \ 13.9996 15.2475 \ 13.9999 21.0790 plane 134.8818 -cart \ 0.0000 0.0000 \ 1.4531 0.0458 \ 3.1092 0.1579 \ 4.7665 0.3036 \ 6.2811 0.4577 \ 7.5653 0.6031 \ 8.5863 0.7311 \ 9.3647 0.8416 \ 9.9583 0.9406 \ 10.4232 1.0349 \ 10.8040 1.1302 \ 11.1337 1.2311 \ 11.4346 1.3414 \ 11.7178 1.4637 \ 11.9845 1.5997 \ 12.2327 1.7511 \ 12.4609 1.9197 \ 12.6688 2.1078 \ 12.8566 2.3179 \ 13.0256 2.5528 \ 13.1781 2.8158 \ 13.3164 3.1113 \ 13.3621 3.2332 \ 13.4419 3.4472 \ 13.5558 3.8345 \ 13.6585 4.2877 \ 13.7494 4.8249 \ 13.8271 5.4676 \ 13.8897 6.2586 \ 13.9364 7.3284 \ 13.9676 8.9239 \ 13.9851 11.4082 \ 13.9921 15.2611 \ 13.9933 21.0790 plane 142.8161 -cart \ 0.0000 0.0000 \ 1.2473 0.0818 \ 2.5695 0.2830 \ 3.8477 0.5463 \ 4.4838 0.6993 \ 5.0036 0.8261 \ 5.9951 1.0902 \ 6.8115 1.3196 \ 7.4737 1.5097 \ 8.0214 1.6669 \ 8.4919 1.7994 \ 8.9138 1.9149 \ 9.3078 2.0206 \ 9.6872 2.1231 \ 10.0574 2.2283 \ 10.4179 2.3415 \ 10.7655 2.4676 \ 11.0979 2.6107 \ 11.4139 2.7743 \ 11.7127 2.9608 \ 11.9950 3.1722 \ 12.2620 3.4093 \ 12.5155 3.6743 \ 12.7561 3.9729 \ 12.9834 4.3152 \ 13.1953 4.7158 \ 13.3885 5.1937 \ 13.5581 5.7725 \ 13.6981 6.4978 \ 13.8045 7.5037 \ 13.8767 9.0400 \ 13.9176 11.4734 \ 13.9337 15.2866 \ 13.9357 21.0790 plane 150.7503 -cart \ 0.0000 0.0014 \ 1.0361 0.1171 \ 2.0483 0.4029 \ 2.9786 0.7806 \ 3.7955 1.1877 \ 4.2503 1.4394 \ 4.4944 1.5779 \ 5.0891 1.9217 \ 5.6002 2.2090 \ 6.0570 2.4448 \ 6.4842 2.6378 \ 6.8998 2.7966 \ 7.3157 2.9294 \ 7.7381 3.0449 \ 8.1679 3.1509 \ 8.6013 3.2556 \ 9.0328 3.3661 \ 9.4582 3.4884 \ 9.8742 3.6271 \ 10.2787 3.7855 \ 10.6712 3.9655 \ 11.0529 4.1676 \ 11.4254 4.3926 \ 11.7891 4.6460 \ 12.1419 4.9374 \ 12.4798 5.2815 \ 12.7957 5.6978 \ 13.0793 6.2109 \ 13.3178 6.8680 \ 13.5016 7.8043 \ 13.6268 9.2703 \ 13.6730 10.8408 \ 13.6941 11.6337 \ 13.7124 15.3739 \ 13.7052 21.0790 plane 158.6845 -cart \ 0.0000 0.0190 \ 0.8333 0.1687 \ 1.5653 0.5365 \ 2.1842 1.0252 \ 2.6950 1.5570 \ 3.1180 2.0730 \ 3.1929 2.1634 \ 3.4889 2.5382 \ 3.8333 2.9330 \ 4.1741 3.2600 \ 4.5290 3.5279 \ 4.9095 3.7462 \ 5.3219 3.9244 \ 5.7673 4.0725 \ 6.2416 4.2002 \ 6.7367 4.3173 \ 7.2431 4.4326 \ 7.7527 4.5530 \ 8.2591 4.6843 \ 8.7580 4.8304 \ 9.2474 4.9936 \ 9.7283 5.1745 \ 10.2024 5.3743 \ 10.2211 5.3834 \ 10.6713 5.6150 \ 11.1251 5.8915 \ 11.5564 6.2165 \ 11.9548 6.6077 \ 12.3065 7.0872 \ 12.5958 7.6989 \ 12.8121 8.5710 \ 12.9530 9.9421 \ 13.0246 12.1609 \ 13.0415 15.6847 \ 13.0270 21.0790 plane 166.6187 -cart \ 0.0000 0.0879 \ 0.6473 0.2789 \ 1.1225 0.7363 \ 1.4546 1.3432 \ 1.4918 1.4416 \ 1.6901 2.0302 \ 1.8697 2.6987 \ 2.0356 3.2936 \ 2.2227 3.7958 \ 2.4529 4.2116 \ 2.7401 4.5534 \ 3.0918 4.8341 \ 3.5097 5.0666 \ 3.6554 5.1260 \ 4.0002 5.2717 \ 4.5468 5.4544 \ 5.1281 5.6225 \ 5.7264 5.7857 \ 6.3265 5.9511 \ 6.9168 6.1236 \ 7.4897 6.3065 \ 8.0417 6.5010 \ 8.5735 6.7070 \ 9.0876 6.9247 \ 9.5840 7.1579 \ 10.0596 7.4144 \ 10.5079 7.7062 \ 10.6795 7.8498 \ 10.9168 8.0510 \ 11.2734 8.4688 \ 11.5651 8.9985 \ 11.7831 9.7593 \ 11.9265 10.9726 \ 12.0021 12.9626 \ 12.0249 16.1556 \ 12.0178 21.0790 plane 174.5530 -cart \ 0.0000 4.3399 \ 0.2579 4.5489 \ 0.3838 4.8962 \ 0.4327 5.2820 \ 0.4528 5.6452 \ 0.4817 5.9565 \ 0.5486 6.2085 \ 0.6771 6.4085 \ 0.8853 6.5707 \ 1.1847 6.7080 \ 1.5789 6.8306 \ 2.0635 6.9470 \ 2.6261 7.0639 \ 2.7129 7.0814 \ 3.2464 7.1880 \ 3.8956 7.3232 \ 4.5471 7.4723 \ 5.1805 7.6372 \ 5.7821 7.8181 \ 6.3448 8.0140 \ 6.8681 8.2223 \ 7.3578 8.4394 \ 7.8227 8.6623 \ 8.2678 8.8917 \ 8.6945 9.1326 \ 9.0994 9.3941 \ 9.4749 9.6895 \ 9.8091 10.0364 \ 10.0876 10.4712 \ 10.3001 11.1025 \ 10.4440 12.1335 \ 10.5240 13.8627 \ 10.5526 16.6826 \ 10.5495 21.0790 plane 182.4872 -cart \ 0.0000 9.5361 \ 0.0041 9.5381 \ 0.0079 9.5422 \ 0.0159 9.5477 \ 0.0350 9.5548 \ 0.0747 9.5637 \ 0.1468 9.5756 \ 0.2656 9.5917 \ 0.4455 9.6139 \ 0.6961 9.6442 \ 1.0204 9.6843 \ 1.4150 9.7360 \ 1.8701 9.8013 \ 2.3694 9.8819 \ 2.8910 9.9794 \ 3.4142 10.0950 \ 3.9233 10.2288 \ 4.4079 10.3799 \ 4.8630 10.5467 \ 5.2893 10.7263 \ 5.6925 10.9151 \ 6.0803 11.1101 \ 6.4572 11.3117 \ 6.8238 11.5238 \ 7.1763 11.7537 \ 7.5071 12.0128 \ 7.8041 12.3159 \ 8.0533 12.6919 \ 8.2443 13.2246 \ 8.3738 14.0690 \ 8.4454 15.4513 \ 8.4696 17.6672 \ 8.4639 21.0790 plane 190.4213 -cart 0.0000 12.4496 0.0961 12.4645 0.1779 12.4772 0.3019 12.4965 0.4747 12.5241 \ 0.6985 12.5613 0.9713 12.6092 1.2869 12.6690 1.6345 12.7414 1.9999 12.8270 \ 2.3693 12.9262 \ 2.7326 13.0387 3.0830 13.1637 3.4175 13.3003 3.7363 13.4467 4.0434 13.6010 4.3436 13.7619 \ 4.6394 13.9306 4.9300 14.1113 5.2115 14.3109 5.4769 14.5391 5.7160 14.8086 \ 5.9169 15.1410 6.0714 15.5898 6.1771 16.2502 6.2375 17.2590 6.2620 18.7951 6.2657 21.0790 end $ $********************************************* combine hull & bow $ &subtitle union mhull bow hull delete_block mhull bow &set subt = union of hull and bow su_show hull $********************************************* combine superstructure bridge &subtitle union two three bridge delete_block two three &set subt = union of top2 and top3 su_show bridge $ $********************************************* combine superstructure funnel & four &subtitle union four five funnel delete_block four five &set subt = union of funnel and four su_show funnel $ $********************************************* combine superstructure funnel & one &subtitle union funnel one mblock delete_block funnel one &set subt = union of funnel and one su_show mblock $ $********************************************* combine whole superstructure &subtitle union bridge mblock ssblock delete_block bridge mblock &set subt = union of whole superstructure su_show ssblock $ $********************************************* combine superstructure and hull &subtitle union ssblock hull mhull delete_block superstructure hull &set subt = union of whole superstructure and hull su_show mhull $ $********************************************* emit meshing &set subt = final hull su_show mhull rename mhull emit mhull -body mhull emit mhull -piece -perm 1 -diftype 3ddif -cs_curr 0 0 0 -tanaka 1 $ $********************************************* finish meshing $ &dimen -remember &finish
Dear Gina,
Here is the update file for tanker modeling (3ddiff). Attached are the errors I received.
Nas
Appreciate your help.
$********************************************* set data $ &dimen -save -dimen metres m-tons &set vlength = 243.00 &set vbeam = 45.00 &set vdepth = 25.00 &set vname = nauticamuar &set lwtf =132027 $ $********************************************* macro for plotting $ ¯o su_show names &if %plot &then &select :n -select %names &if %demo &then &device -g_default screen &subtitle %subt picture iso &picture iso -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &subtitle %subt picture top &picture top -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &subtitle %subt picture bow &picture bow -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &subtitle %subt picture stab &picture stab -parent :n &local dum = &get (yes/no) &if &string (match %dum% yes) &then &endif &else &device -g_default device &subtitle %subt picture iso &picture iso -parent :n &subtitle %subt picture top &picture top -parent :n &subtitle %subt picture bow &picture bow -parent :n &subtitle %subt picture stab &picture stab -parent :n &endif &endmacro $ $********************************************* generate &surface $ $********************************************* define body $ $*cgfsumuar 119.166 0 11.724 $&weight *cgfsumuar %lwrf 0.29*%vbeam% 0.32*%vlength% 0.32*%vlength% $ $********************************************* dimensions $ $ format (-locat translate x,y,z (rot-x roll)(rot-y pitch) (rot-z yaw)*********** $ $****pgen cabin -perm 0 -diftype none $$$$$$-locat "(translate)x coordi=6.5m" "(translate)y+ve@port= 0m" (translate)(depth-base)=13.01m $$$$$$(rotate@x-axis-ccw)=0deg (rotate@y-axis)=-90 (rotate@z-axis)=0 %win_cur $***after -locat the distance will be zero after locate x-translate!!********* $***-locat translate from midpoint surface!!********************************* $**pgen = origin,height.witdh*************** $ $ $______________create superstructure________________________ $ $ $************************************************************** block one -loc 149 0 16.95 0 0 0 plane 0 17 -rect 0 14.5 20.41 end $ block two -loc 149 0 31.45 0 0 0 plane 0 4 -rect 0 1.63 30 end $ block three -loc 149 0 31.45 0 0 0 plane 0 16 -rect 0 4 16 end $ block four -loc 149 0 16.95 0 0 0 plane 0 29.5 -rect 0 10 14.6 end $ block five -loc 149 0 16.95 0 0 0 plane 0 29.5 -rect 0 14 10 end $ $ $ $**************************************** bulbous bow $ block bulb PLANE 1.000 -CART 0 2.359 0.191 2.921 0.337 3.49 0.454 4.085 \ 0.534 4.778 0.546 5.633 0.423 6.574 0.159 7.468 0.017 7.785 PLANE 2.500 -CART 0 1.377 \ 0.3 1.912 \ 0.517 2.384 \ 0.722 2.923 \ 0.902 3.501 \ 1.047 4.102 \ 1.148 4.793 \ 1.172 5.629 \ 1.042 6.535 \ 0.743 7.396 \ 0.386 8.12 \ 0.088 8.701 \ 0.000 8.944 PLANE 3.000 -CART 0 1.22 \ 0.212 1.499 \ 0.444 1.9 \ 0.679 2.38 \ 0.899 2.923 \ 1.09 3.504 \ 1.244 4.108 \ 1.353 4.798 \ 1.381 5.628 \ 1.248 6.522 \ 0.938 7.372 \ 0.563 8.1 \ 0.247 8.704 \ 0.000 9.105 PLANE 4.000 -CART 0.000 0.923 \ 0.178 1.101 \ 0.446 1.441 \ 0.731 1.874 \ 1.004 2.372 \ 1.252 2.924 \ 1.465 3.509 \ 1.625 4.104 \ 1.742 4.785 \ 1.781 5.602 \ 1.656 6.488 \ 1.327 7.324 \ 0.918 8.059 \ 0.564 8.710 \ 0.000 9.372 PLANE 4.125 -CART 0.000 0.923 \ 0.178 1.101 \ 0.446 1.441 \ 0.731 1.874 \ 1.004 2.372 \ 1.252 2.924 \ 1.465 3.509 \ 1.625 4.104 \ 1.742 4.785 \ 1.781 5.602 \ 1.656 6.488 \ 1.327 7.324 \ 0.918 8.059 \ 0.564 8.710 \ 0 9.372 end $**************************************** fore fwd $ &surface block fore PLANE 1.000 -CART 0.000 15.745 \ 0.589 16.382 \ 0.825 16.65 \ 1.069 16.885 \ 1.325 17.089 \ PLANE 2.500 -CART 0.000 13.935 \ 0.740 15.229 \ 1.011 15.599 \ 1.317 15.934 \ 1.635 16.233 \ 1.949 16.496 \ 2.257 16.724 \ 2.567 16.921 \ 2.882 17.087 PLANE 3.000 -CART 0.000 13.130 \ 0.596 14.498 \ 1.081 15.316 \ 1.715 15.997 \ 2.402 16.534 \ 3.066 16.933 \ 3.401 17.087 PLANE 4.000 -CART 0.000 11.469 \ 0.526 13.248 \ 0.94 14.253 \ 1.456 15.114 \ 2.118 15.825 \ 2.916 16.385 \ 3.63 16.783 \ 4.268 17.085 PLANE 4.125 -CART 0.000 0.923 \ 0.178 1.101 \ 0.446 1.441 \ 0.731 1.874 \ 1.004 2.372 \ 1.252 2.924 \ 1.465 3.509 \ 1.625 4.104 \ 1.742 4.785 \ 1.781 5.602 \ 1.656 6.488 \ 1.327 7.324 \ 0.918 8.059 \ 0.564 8.710 \ 0 9.372 end $****************************************** hull body $ block a_hull PLANE 4.125 -CART \ 0.0024 0.5667 \ 0.3545 0.8735 \ 0.7115 1.2397 \ 1.0572 1.6597 \ 1.3752 2.1285 \ 1.6606 2.6475 \ 1.9092 3.2028 \ 2.1144 3.7866 \ 2.2716 4.4544 \ 2.3536 5.2532 \ 2.2863 6.1248 \ 2.0396 6.9794 \ 1.6906 7.7663 \ 1.3519 8.5021 \ 1.1148 9.2529 \ 1.0038 10.0280 \ 0.9935 10.7826 \ 1.0647 11.4910 \ 1.2040 12.1468 \ 1.3939 12.7482 \ 1.6191 13.2976 \ 1.8705 13.8012 \ 2.1428 14.2631 \ 2.4337 14.6841 \ 2.7456 15.0659 \ 3.0824 15.4113 \ 3.4452 15.7236 \ 3.8237 16.0065 \ 4.1959 16.2638 \ 4.5497 16.4977 \ 4.8871 16.7103 \ 5.2142 16.9033 \ 5.5356 17.0782 PLANE 6.0000 -CART \ 0.0024 0.5667 \ 0.3545 0.8735 \ 0.7115 1.2397 \ 1.0572 1.6597 \ 1.3752 2.1285 \ 1.6606 2.6475 \ 1.9092 3.2028 \ 2.1144 3.7866 \ 2.2716 4.4544 \ 2.3536 5.2532 \ 2.2863 6.1248 \ 2.0396 6.9794 \ 1.6906 7.7663 \ 1.3519 8.5021 \ 1.1148 9.2529 \ 1.0038 10.0280 \ 0.9935 10.7826 \ 1.0647 11.4910 \ 1.2040 12.1468 \ 1.3939 12.7482 \ 1.6191 13.2976 \ 1.8705 13.8012 \ 2.1428 14.2631 \ 2.4337 14.6841 \ 2.7456 15.0659 \ 3.0824 15.4113 \ 3.4452 15.7236 \ 3.8237 16.0065 \ 4.1959 16.2638 \ 4.5497 16.4977 \ 4.8871 16.7103 \ 5.2142 16.9033 \ 5.5356 17.0782 PLANE 8.0353 -CART \ 0.0094 0.3582 \ 0.4375 0.6481 \ 0.8879 0.9959 \ 1.3210 1.3973 \ 1.7122 1.8484 \ 2.0594 2.3506 \ 2.3612 2.8913 \ 2.6121 3.4640 \ 2.8106 4.1186 \ 2.9366 4.8987 \ 2.9282 5.7548 \ 2.7592 6.6087 \ 2.4937 7.4146 \ 2.2329 8.1779 \ 2.0665 8.9403 \ 2.0203 9.7083 \ 2.0711 10.4550 \ 2.1979 11.1650 \ 2.3843 11.8321 \ 2.6119 12.4480 \ 2.8666 13.0104 \ 3.1421 13.5259 \ 3.4352 13.9999 \ 3.7439 14.4346 \ 4.0682 14.8326 \ 4.4084 15.1972 \ 4.7628 15.5323 \ 5.1244 15.8414 \ 5.4817 16.1273 \ 5.8285 16.3916 \ 6.1660 16.6361 \ 6.4975 16.8623 \ 6.8256 17.0715 PLANE 16.3097 -CART \ 0.0081 0.0138 \ 0.6396 0.0798 \ 1.5773 0.2164 \ 2.5427 0.4259 \ 3.2760 0.7100 \ 3.8549 1.0702 \ 4.3660 1.4951 \ 4.8163 1.9781 \ 5.2153 2.5587 \ 5.5710 3.2749 \ 5.8630 4.0963 \ 6.0766 4.9642 \ 6.2276 5.8328 \ 6.3491 6.6808 \ 6.4765 7.5069 \ 6.6273 8.3076 \ 6.8031 9.0758 \ 7.0029 9.8078 \ 7.2254 10.5020 \ 7.4687 11.1553 \ 7.7299 11.7665 \ 8.0051 12.3383 \ 8.2891 12.8747 \ 8.5764 13.3805 \ 8.8621 13.8596 \ 9.1425 14.3153 \ 9.4145 14.7510 \ 9.6771 15.1691 \ 9.9319 15.5713 \ 10.1799 15.9588 \ 10.4213 16.3331 \ 10.6557 16.6951 \ 10.8835 17.0457 PLANE 24.5841 -CART \ 0.0149 0.0171 \ 0.6561 0.0286 \ 2.6174 0.0868 \ 4.7357 0.2027 \ 5.9513 0.3938 \ 6.6390 0.6705 \ 7.2131 1.0255 \ 7.7322 1.4509 \ 8.2174 1.9777 \ 8.6867 2.6377 \ 9.1116 3.4088 \ 9.4614 4.2431 \ 9.7376 5.0985 \ 9.9541 5.9493 \ 10.1272 6.7859 \ 10.2736 7.5998 \ 10.4083 8.3826 \ 10.5425 9.1299 \ 10.6831 9.8411 \ 10.8344 10.5176 \ 10.9964 11.1611 \ 11.1656 11.7726 \ 11.3378 12.3542 \ 11.5101 12.9087 \ 11.6799 13.4389 \ 11.8454 13.9470 \ 12.0053 14.4350 \ 12.1586 14.9049 \ 12.3046 15.3582 \ 12.4432 15.7960 \ 12.5747 16.2196 \ 12.6999 16.6300 \ 12.8196 17.0281 PLANE 32.8585 -CART \ 0.0022 0.0122 \ 0.7165 0.0471 \ 3.6839 0.1222 \ 6.8915 0.2431 \ 8.5228 0.4260 \ 9.2503 0.6845 \ 9.8105 1.0190 \ 10.3097 1.4291 \ 10.7628 1.9455 \ 11.1838 2.5958 \ 11.5478 3.3559 \ 11.8308 4.1762 \ 12.0401 5.0114 \ 12.1941 5.8357 \ 12.3112 6.6426 \ 12.4072 7.4281 \ 12.4936 8.1871 \ 12.5772 8.9180 \ 12.6621 9.6200 \ 12.7515 10.2920 \ 12.8420 10.9344 \ 12.9240 11.5501 \ 12.9973 12.1414 \ 13.0695 12.7094 \ 13.1426 13.2555 \ 13.2142 13.7817 \ 13.2834 14.2896 \ 13.3501 14.7803 \ 13.4152 15.2550 \ 13.4790 15.7145 \ 13.5416 16.1598 \ 13.6031 16.5915 \ 13.6633 17.0107 PLANE 41.1329 -CART \ 0.0000 0.0147 \ 1.0103 0.0468 \ 4.6959 0.1301 \ 8.5051 0.2625 \ 10.3478 0.4538 \ 11.0819 0.7230 \ 11.6035 1.0800 \ 12.0295 1.5262 \ 12.3732 2.0681 \ 12.6606 2.7054 \ 12.8861 3.4135 \ 13.0453 4.1577 \ 13.1591 4.9073 \ 13.2469 5.6471 \ 13.3166 6.3756 \ 13.3750 7.0911 \ 13.4278 7.7898 \ 13.4775 8.4705 \ 13.5261 9.1336 \ 13.5775 9.7794 \ 13.6283 10.4092 \ 13.6684 11.0248 \ 13.6978 11.6268 \ 13.7265 12.2151 \ 13.7577 12.7900 \ 13.7900 13.3526 \ 13.8231 13.9036 \ 13.8572 14.4439 \ 13.8917 14.9742 \ 13.9259 15.4953 \ 13.9597 16.0079 \ 13.9930 16.5126 \ 14.0257 17.0098 PLANE 49.4073 -CART \ 0.0000 0.0139 \ 2.2496 0.0392 \ 6.4928 0.1124 \ 9.8783 0.2307 \ 11.4770 0.4103 \ 12.1659 0.6859 \ 12.6441 1.0792 \ 12.9765 1.5830 \ 13.1955 2.1556 \ 13.3658 2.7514 \ 13.4969 3.3591 \ 13.5849 3.9791 \ 13.6478 4.6032 \ 13.6991 5.2266 \ 13.7394 5.8505 \ 13.7718 6.4750 \ 13.8018 7.0990 \ 13.8311 7.7223 \ 13.8593 8.3451 \ 13.8872 8.9673 \ 13.9139 9.5888 \ 13.9367 10.2102 \ 13.9556 10.8313 \ 13.9736 11.4521 \ 13.9917 12.0723 \ 14.0095 12.6921 \ 14.0268 13.3115 \ 14.0439 13.9305 \ 14.0608 14.5492 \ 14.0773 15.1676 \ 14.0934 15.7856 \ 14.1093 16.4034 \ 14.1249 17.0209 PLANE 57.6816 -CART \ 0.0000 0.0139 \ 4.2929 0.0341 \ 8.9851 0.0933 \ 11.1019 0.1868 \ 12.0881 0.3366 \ 12.7056 0.5950 \ 13.1683 0.9972 \ 13.4426 1.5331 \ 13.5810 2.1295 \ 13.6844 2.7106 \ 13.7685 3.2737 \ 13.8219 3.8396 \ 13.8590 4.4104 \ 13.8910 4.9844 \ 13.9167 5.5642 \ 13.9369 6.1508 \ 13.9557 6.7441 \ 13.9742 7.3443 \ 13.9917 7.9515 \ 14.0084 8.5655 \ 14.0240 9.1860 \ 14.0379 9.8128 \ 14.0502 10.4456 \ 14.0618 11.0839 \ 14.0732 11.7274 \ 14.0841 12.3757 \ 14.0946 13.0285 \ 14.1048 13.6855 \ 14.1148 14.3463 \ 14.1246 15.0109 \ 14.1341 15.6788 \ 14.1436 16.3499 \ 14.1528 17.0239 PLANE 65.9560 -CART \ 0.0000 0.0141 \ 5.3870 0.0298 \ 10.3055 0.0762 \ 11.7271 0.1449 \ 12.3839 0.2606 \ 12.9731 0.4913 \ 13.4377 0.8855 \ 13.6823 1.4353 \ 13.7745 2.0561 \ 13.8434 2.6590 \ 13.9059 3.2417 \ 13.9421 3.8291 \ 13.9650 4.4206 \ 13.9862 5.0130 \ 14.0036 5.6089 \ 14.0172 6.2098 \ 14.0298 6.8151 \ 14.0422 7.4248 \ 14.0537 8.0392 \ 14.0645 8.6581 \ 14.0747 9.2815 \ 14.0838 9.9092 \ 14.0919 10.5408 \ 14.0995 11.1762 \ 14.1069 11.8150 \ 14.1142 12.4570 \ 14.1213 13.1020 \ 14.1284 13.7498 \ 14.1353 14.4001 \ 14.1421 15.0529 \ 14.1488 15.7080 \ 14.1554 16.3652 \ 14.1619 17.0244 PLANE 74.2304 -CART \ 0.0000 0.0139 \ 5.5420 0.0256 \ 10.5283 0.0609 \ 11.8965 0.1079 \ 12.5295 0.1926 \ 13.1282 0.3960 \ 13.5993 0.7779 \ 13.8268 1.3347 \ 13.8899 1.9800 \ 13.9390 2.6208 \ 13.9905 3.2521 \ 14.0172 3.8939 \ 14.0314 4.5387 \ 14.0457 5.1787 \ 14.0574 5.8170 \ 14.0659 6.4547 \ 14.0741 7.0902 \ 14.0823 7.7234 \ 14.0900 8.3547 \ 14.0970 8.9840 \ 14.1036 9.6114 \ 14.1099 10.2369 \ 14.1158 10.8607 \ 14.1214 11.4829 \ 14.1268 12.1035 \ 14.1319 12.7228 \ 14.1369 13.3407 \ 14.1417 13.9574 \ 14.1463 14.5730 \ 14.1509 15.1875 \ 14.1554 15.8010 \ 14.1598 16.4135 \ 14.1642 17.0252 PLANE 82.5048 -CART \ 0.0000 0.0140 \ 5.4861 0.0222 \ 10.4942 0.0480 \ 11.9401 0.0768 \ 12.6121 0.1355 \ 13.2261 0.3158 \ 13.7039 0.6856 \ 13.9204 1.2455 \ 13.9638 1.9117 \ 14.0006 2.5911 \ 14.0459 3.2749 \ 14.0664 3.9760 \ 14.0745 4.6787 \ 14.0838 5.3709 \ 14.0916 6.0554 \ 14.0968 6.7332 \ 14.1018 7.4017 \ 14.1071 8.0602 \ 14.1119 8.7095 \ 14.1165 9.3496 \ 14.1209 9.9808 \ 14.1252 10.6035 \ 14.1293 11.2182 \ 14.1332 11.8254 \ 14.1371 12.4256 \ 14.1409 13.0193 \ 14.1445 13.6068 \ 14.1482 14.1887 \ 14.1517 14.7652 \ 14.1552 15.3368 \ 14.1587 15.9038 \ 14.1621 16.4665 \ 14.1654 17.0252 PLANE 90.7792 -CART \ 0.0000 0.0140 \ 4.6049 0.0193 \ 9.5028 0.0376 \ 11.6092 0.0529 \ 12.6109 0.0937 \ 13.2846 0.2585 \ 13.7707 0.6203 \ 13.9794 1.1822 \ 14.0096 1.8647 \ 14.0386 2.5779 \ 14.0803 3.3090 \ 14.0969 4.0637 \ 14.1009 4.8186 \ 14.1070 5.5577 \ 14.1122 6.2839 \ 14.1151 6.9977 \ 14.1178 7.6956 \ 14.1209 8.3767 \ 14.1238 9.0419 \ 14.1266 9.6913 \ 14.1297 10.3254 \ 14.1327 10.9449 \ 14.1358 11.5507 \ 14.1389 12.1437 \ 14.1420 12.7246 \ 14.1451 13.2942 \ 14.1482 13.8534 \ 14.1512 14.4029 \ 14.1542 14.9432 \ 14.1572 15.4751 \ 14.1601 15.9990 \ 14.1630 16.5156 \ 14.1659 17.0252 PLANE 99.0536 -CART \ 0.0000 0.0140 \ 2.4041 0.0172 \ 6.5498 0.0302 \ 9.9565 0.0382 \ 12.0332 0.0721 \ 13.1831 0.2331 \ 13.7911 0.5941 \ 14.0036 1.1576 \ 14.0266 1.8500 \ 14.0517 2.5874 \ 14.0914 3.3540 \ 14.1061 4.1486 \ 14.1083 4.9422 \ 14.1129 5.7163 \ 14.1169 6.4734 \ 14.1188 7.2137 \ 14.1204 7.9331 \ 14.1222 8.6306 \ 14.1239 9.3070 \ 14.1259 9.9627 \ 14.1283 10.5981 \ 14.1310 11.2144 \ 14.1339 11.8126 \ 14.1370 12.3938 \ 14.1402 12.9591 \ 14.1434 13.5097 \ 14.1467 14.0464 \ 14.1500 14.5703 \ 14.1533 15.0822 \ 14.1566 15.5830 \ 14.1599 16.0733 \ 14.1632 16.5538 \ 14.1664 17.0252 PLANE 107.3280 -CART \ 0.0000 0.0141 \ 1.1434 0.0158 \ 3.9459 0.0251 \ 7.4694 0.0315 \ 10.7302 0.0697 \ 12.8599 0.2394 \ 13.7613 0.6079 \ 13.9924 1.1734 \ 14.0132 1.8699 \ 14.0375 2.6235 \ 14.0768 3.4161 \ 14.0915 4.2393 \ 14.0938 5.0606 \ 14.0988 5.8598 \ 14.1033 6.6389 \ 14.1055 7.3980 \ 14.1069 8.1325 \ 14.1082 8.8411 \ 14.1095 9.5247 \ 14.1115 10.1838 \ 14.1142 10.8190 \ 14.1175 11.4315 \ 14.1212 12.0227 \ 14.1252 12.5938 \ 14.1295 13.1462 \ 14.1339 13.6811 \ 14.1385 14.1996 \ 14.1432 14.7030 \ 14.1479 15.1922 \ 14.1527 15.6682 \ 14.1574 16.1318 \ 14.1621 16.5839 \ 14.1668 17.0252 PLANE 115.6024 -CART \ 0.0000 0.0137 \ 2.2858 0.0137 \ 5.0801 0.0209 \ 7.6515 0.0320 \ 10.5937 0.0866 \ 12.7685 0.2788 \ 13.6864 0.6637 \ 13.9143 1.2315 \ 13.9394 1.9266 \ 13.9678 2.6894 \ 14.0098 3.5000 \ 14.0280 4.3428 \ 14.0343 5.1827 \ 14.0431 5.9988 \ 14.0513 6.7926 \ 14.0565 7.5638 \ 14.0600 8.3076 \ 14.0629 9.0227 \ 14.0659 9.7100 \ 14.0699 10.3699 \ 14.0750 11.0033 \ 14.0809 11.6114 \ 14.0874 12.1957 \ 14.0944 12.7576 \ 14.1020 13.2986 \ 14.1098 13.8201 \ 14.1177 14.3234 \ 14.1258 14.8099 \ 14.1339 15.2805 \ 14.1420 15.7364 \ 14.1501 16.1786 \ 14.1582 16.6079 \ 14.1662 17.0252 PLANE 123.8768 -CART \ 0.0000 0.0142 \ 3.3685 0.0131 \ 7.5343 0.0208 \ 10.1344 0.0496 \ 11.8676 0.1513 \ 12.9530 0.4032 \ 13.5007 0.8309 \ 13.6917 1.4038 \ 13.7334 2.0846 \ 13.7749 2.8434 \ 13.8254 3.6587 \ 13.8550 4.5050 \ 13.8738 5.3472 \ 13.8935 6.1661 \ 13.9116 6.9620 \ 13.9254 7.7339 \ 13.9354 8.4771 \ 13.9434 9.1902 \ 13.9517 9.8741 \ 13.9616 10.5292 \ 13.9734 11.1564 \ 13.9865 11.7570 \ 14.0003 12.3328 \ 14.0151 12.8850 \ 14.0307 13.4153 \ 14.0468 13.9251 \ 14.0631 14.4157 \ 14.0796 14.8886 \ 14.0961 15.3449 \ 14.1127 15.7857 \ 14.1292 16.2121 \ 14.1457 16.6250 \ 14.1621 17.0252 PLANE 132.1512 -CART \ 0.0000 0.0139 \ 2.1083 0.0102 \ 6.4172 0.0248 \ 10.0340 0.0815 \ 11.7586 0.2384 \ 12.4381 0.5552 \ 12.8177 1.0262 \ 13.0118 1.5983 \ 13.1024 2.2556 \ 13.1866 3.0016 \ 13.2720 3.8128 \ 13.3393 4.6525 \ 13.3954 5.4877 \ 13.4485 6.3016 \ 13.4973 7.0925 \ 13.5396 7.8587 \ 13.5751 8.5962 \ 13.6065 9.3036 \ 13.6378 9.9813 \ 13.6711 10.6299 \ 13.7062 11.2504 \ 13.7414 11.8443 \ 13.7764 12.4132 \ 13.8127 12.9583 \ 13.8502 13.4809 \ 13.8877 13.9829 \ 13.9250 14.4657 \ 13.9617 14.9305 \ 13.9979 15.3787 \ 14.0337 15.8112 \ 14.0690 16.2292 \ 14.1038 16.6336 \ 14.1382 17.0252 PLANE 140.4256 -CART \ 0.0000 0.0119 \ 0.8962 0.0060 \ 4.3280 0.0391 \ 8.0130 0.1176 \ 9.9432 0.2812 \ 10.7511 0.5898 \ 11.2088 1.0421 \ 11.4900 1.5897 \ 11.6821 2.2278 \ 11.8589 2.9676 \ 12.0287 3.7796 \ 12.1791 4.6201 \ 12.3145 5.4572 \ 12.4415 6.2745 \ 12.5617 7.0680 \ 12.6742 7.8352 \ 12.7779 8.5736 \ 12.8754 9.2823 \ 12.9705 9.9612 \ 13.0652 10.6108 \ 13.1582 11.2323 \ 13.2451 11.8281 \ 13.3271 12.3993 \ 13.4095 12.9461 \ 13.4927 13.4699 \ 13.5740 13.9729 \ 13.6523 14.4568 \ 13.7276 14.9231 \ 13.8003 15.3727 \ 13.8706 15.8068 \ 13.9388 16.2263 \ 14.0054 16.6322 \ 14.0702 17.0252 PLANE 148.7000 -CART \ 0.0000 0.0183 \ 0.5180 0.0337 \ 2.5369 0.0898 \ 5.1458 0.1800 \ 7.2157 0.3340 \ 8.5060 0.6064 \ 9.1993 1.0096 \ 9.5971 1.5203 \ 9.8915 2.1433 \ 10.1567 2.8849 \ 10.4070 3.7057 \ 10.6396 4.5543 \ 10.8614 5.3978 \ 11.0798 6.2200 \ 11.2978 7.0163 \ 11.5146 7.7832 \ 11.7268 8.5184 \ 11.9295 9.2237 \ 12.1210 9.9014 \ 12.3053 10.5506 \ 12.4816 11.1720 \ 12.6424 11.7695 \ 12.7891 12.3445 \ 12.9307 12.8960 \ 13.0692 13.4249 \ 13.2018 13.9332 \ 13.3277 14.4227 \ 13.4473 14.8945 \ 13.5613 15.3497 \ 13.6702 15.7895 \ 13.7745 16.2148 \ 13.8748 16.6266 \ 13.9712 17.0256 PLANE 156.9744 -CART \ 0.0000 0.0000 \ 0.7298 0.0178 \ 2.0090 0.1059 \ 3.5853 0.2618 \ 5.3349 0.4909 \ 6.6546 0.8190 \ 7.3676 1.2487 \ 7.7885 1.7660 \ 8.1255 2.3897 \ 8.4325 3.1362 \ 8.7234 3.9668 \ 9.0072 4.8241 \ 9.3018 5.6670 \ 9.6178 6.4750 \ 9.9536 7.2443 \ 10.3016 7.9751 \ 10.6501 8.6702 \ 10.9824 9.3383 \ 11.2879 9.9866 \ 11.5712 10.6135 \ 11.8360 11.2173 \ 12.0787 11.7996 \ 12.3006 12.3615 \ 12.5080 12.9026 \ 12.7032 13.4240 \ 12.8854 13.9272 \ 13.0552 14.4135 \ 13.2136 14.8839 \ 13.3617 15.3392 \ 13.5001 15.7804 \ 13.6297 16.2082 \ 13.7513 16.6234 \ 13.8654 17.0266 PLANE 165.2488 -CART \ 0.0012 0.0578 \ 1.0654 0.1405 \ 2.2829 0.3507 \ 3.1219 0.6695 \ 3.9263 1.0917 \ 4.5605 1.6029 \ 4.9634 2.1678 \ 5.2687 2.7563 \ 5.5730 3.4026 \ 5.9081 4.1484 \ 6.2770 4.9582 \ 6.6777 5.7706 \ 7.1154 6.5462 \ 7.5894 7.2695 \ 8.0885 7.9441 \ 8.5975 8.5785 \ 9.0992 9.1828 \ 9.5758 9.7678 \ 10.0153 10.3413 \ 10.4175 10.9045 \ 10.7861 11.4561 \ 11.1240 11.9948 \ 11.4334 12.5200 \ 11.7168 13.0311 \ 11.9770 13.5281 \ 12.2169 14.0108 \ 12.4388 14.4795 \ 12.6445 14.9346 \ 12.8350 15.3769 \ 13.0116 15.8070 \ 13.1751 16.2254 \ 13.3264 16.6328 \ 13.4666 17.0297 PLANE 173.5232 -CART \ 0.0325 2.1141 \ 0.5805 2.3866 \ 1.1778 2.7548 \ 1.5330 3.1701 \ 1.8160 3.6863 \ 2.0558 4.2717 \ 2.2587 4.8622 \ 2.4629 5.4164 \ 2.7331 5.9776 \ 3.1204 6.5994 \ 3.6175 7.2429 \ 4.1867 7.8505 \ 4.7890 8.4095 \ 5.3966 8.9291 \ 5.9941 9.4246 \ 6.5719 9.9059 \ 7.1237 10.3764 \ 7.6467 10.8369 \ 8.1386 11.2887 \ 8.5940 11.7361 \ 9.0081 12.1836 \ 9.3799 12.6334 \ 9.7125 13.0836 \ 10.0125 13.5297 \ 10.2866 13.9674 \ 10.5405 14.3936 \ 10.7783 14.8069 \ 11.0025 15.2071 \ 11.2140 15.5949 \ 11.4137 15.9713 \ 11.6026 16.3369 \ 11.7812 16.6925 \ 11.9495 17.0392 PLANE 181.7976 -CART \ 0.0660 6.9961 \ 0.2649 7.2401 \ 0.5085 7.5069 \ 0.7997 7.7741 \ 1.1450 8.0741 \ 1.4754 8.3977 \ 1.7607 8.7178 \ 2.0341 9.0174 \ 2.3495 9.3235 \ 2.7440 9.6686 \ 3.2060 10.0357 \ 3.7029 10.3955 \ 4.2071 10.7388 \ 4.6993 11.0712 \ 5.1689 11.4039 \ 5.6116 11.7400 \ 6.0271 12.0756 \ 6.4152 12.4086 \ 6.7745 12.7395 \ 7.1015 13.0712 \ 7.3928 13.4061 \ 7.6483 13.7453 \ 7.8718 14.0864 \ 8.0699 14.4248 \ 8.2489 14.7567 \ 8.4137 15.0797 \ 8.5679 15.3926 \ 8.7142 15.6946 \ 8.8544 15.9859 \ 8.9896 16.2668 \ 9.1202 16.5380 \ 9.2460 16.8005 \ 9.3666 17.0553 PLANE 190.0719 -CART \ 0.0000 10.6979 \ 0.2803 10.7958 \ 0.5600 10.9011 \ 0.8377 11.0140 \ 1.1110 11.1347 \ 1.3804 11.2643 \ 1.6436 11.4008 \ 1.9017 11.5432 \ 2.1746 11.7028 \ 2.4817 11.8914 \ 2.8160 12.1046 \ 3.1604 12.3305 \ 3.5028 12.5596 \ 3.8352 12.7884 \ 4.1515 13.0189 \ 4.4466 13.2522 \ 4.7163 13.4883 \ 4.9584 13.7271 \ 5.1717 13.9691 \ 5.3555 14.2144 \ 5.5107 14.4626 \ 5.6403 14.7124 \ 5.7492 14.9613 \ 5.8430 15.2065 \ 5.9263 15.4461 \ 6.0021 15.6787 \ 6.0732 15.9035 \ 6.1419 16.1195 \ 6.2102 16.3264 \ 6.2787 16.5241 \ 6.3468 16.7138 \ 6.4138 16.8966 \ 6.4789 17.0733 end $ $********************************************* combine hull & bow $ &subtitle union a_hull bulb b_hull delete_block a_hull bulb &set subt = union of hull and bow su_show b_hull $ &subtitle union b_hull fore c_hull delete_block b_hull fore &set subt = union of hull fore su_show c_hull $ $********************************************* combine superstructure bridge &subtitle union two three bridge delete_block two three &set subt = union of top2 and top3 su_show bridge $ $********************************************* combine superstructure funnel & four &subtitle union four five funnel delete_block four five &set subt = union of funnel and four su_show funnel $ $********************************************* combine superstructure funnel & one &subtitle union funnel one mblock delete_block funnel one &set subt = union of funnel and one su_show mblock $ $********************************************* combine whole superstructure &subtitle union bridge mblock ssblock delete_block bridge mblock &set subt = union of whole superstructure su_show ssblock $ $********************************************* combine superstructure and hull &subtitle union ssblock c_hull d_hull delete_block ssblock c_hull &set subt = union of whole superstructure and hull su_show v_hull $ $********************************************* emit meshing &set subt = final v_hull su_show v_hull rename v_hull emit v_hull -body v_hull emit v_hull -piece -perm 1 -diftype 3ddif -cs_curr 0 0 0 -tanaka 1 $ $********************************************* finish meshing $ &dimen -remember &finish
Hi Nas,
Can you contact me at georgina.maldonado@bentley.com?
Thank you,
Georgina
