Dear friends,
I write to you concerning program Maxsurf Resistance v. 21.11/2017/ as has noted some errors and I want to straighten out some vague problems.
The remarked errors and vagueness in the manual of the program are following:
How to make calculation of resistance and power of model of yachts from one or double chine if remaining parameters correspond to methods Delft?
What other method can be applied to hard-chine yachts approximately in semi-planing mode?
For what outlines this method concerns - for every ones /including round-bilge/ or only for hard-chine /prismatic with bottom deadrise /?
The problem has arisen as in the specified text is written “planing hull”- for me a hard chine and bottom deadrise is means, i.e. the model have potentials for operation in a gliding mode, but because of different reasons /for example changing of the engine / is necessary to make examination of the possibility to maintain the model in semi-planing or displacement mode.
Except for that in publication Savitsky - Brown, 1976 the example for application of methods Savitsky pre-planing and Savitsky Planing for a gliding vessel with length LWL = 80ft with prismatic outlines /hard chine, spray rail and deadrise of the bottom/ is shown.
At position that these two methods are applied for one model with gliding hard-chine outlines for me this example is acknowledgement of the conclusion that method Savitsky pre-planing cannot be applied to not gliding models that for me is equivalent on round-bilge.
But if to edit the text in the manual on page 5 /enclosed with a red line/ and he looks approximately so:
„ This algorithm is useful for estimating the resistance of a semi - planing hulls with a round bilge or hard chine and speed corresponding to FnV from 1 to 2 /see page 55/, i.e. its pre-planing resistance”.
Then I agree that method Savitsky pre-planing can be applied to any outlines.
But again there is a problem - how to make the resistance calculation of round-bilge vessels with FnV above 2? Likely the answer is only one - on method Lahtiharju /round bilge/ at which FnV = 1,5 - 3,8.
And more one opinion for upper bound of FnV for gliding round-bilge models:
In the book of Russian scientists Egorov I.T., Bun'kov M.M., Sadovnikov Y.M. “Planing ship propulsion and seaworthiness of planning ships” 1978 –on page 106 there is a very important conclusion:
„ The border of intelligent use of the round-bilge outlines for high-speed boats corresponds to Froude numbers FnV < or = 2,5. At major Froude numbers it is necessary to apply a hard-chine geometric shape. ”
Except for that at gliding we have running trim aft ward, i.e. the bow raised, and on method Slender Body the trim is not taken into account.
Yours faithfully, NA Razmik Baharyan
Rousse - Bulgaria
I hail the readers of the forum,
All know that the truth is born in disputes.
Today is the twentieth day from my publication /197 views/.
I guessed that together with you we shall be witnesses of a brisk controversy during which about all problems which I wrote if not on 100 % but even the majority of them will be explained and clarified.
But alas, there is no controversy!
Writers of the program have not found necessary to consider these problems and to answer them.
As well anybody from ship-building experts on hydrodynamics has not wanted to comment.
Likely it means also small interest to the program.
As against this forum, in Russian forum „Motorboat and Yacht” there was very brisk controversy on this subject, even the paper of the Cand.Tech.Sci. Albert Nazarov from Ukraine has been quoted - see http: // katera.ru/files/magazines/237/110-113.pdf in which he expresses reserved about method Wyman for definition resistance of movement of the vessel.
I ask you to comment on all these problems!
Otherwise I shall think that HydroComp NavCAD /competitive program/ meets the requirements experts on hydrodynamics for making accounts on resistance and power of propulsion systems of vessels better.
NA Razmik Baharyan
I apologize about the inaccuracy: instead of " iges file " it is necessary to read " attached file ".NA Razmik Baharyan
