Free-field soil displacement due to lateral spreading load during earthquake
Dear sir,
During earthquake, soil liquefaction might be a concern especially when non-liquefied layer is underlying by liquefied soil.
Lateral spreading load due to non-liquefied soil movement on top of liquefied layer might be critical for pile design.
In case of geotechnical engineer gave an input as free-field soil horizontal displacement profile along the pile depth.
How can we implement this information in SACS i.e. p-y modification or other methodologies ?
It is a movement of at the boundary end of spring not at the pile side.
Can you help to suggest the modelling technique for this issue ?
Kasiphon
  • An interesting question, Kasiphon ! I can think of two  options; one with shifted P-y curves with the data given by your Geotechnical Engineer. secondly using P-y curve with constant P's for all y values. These we use for mud slide modeling. I prefer the shifted P-y method, as this can be used for crust soil lateral springs modeling. I afraid you may land up in convergence issues; so some TABR modification may be necessary. Good luck and interested to know the outcome of your trials.
Reply
