Dear Geoff and other,
I have question about superelement.
Is it possible for create 2 levels of superelement in SACS?
Fex,
We import super-element from party 'A' to apply at joint #1.
In our analysis, we also need to create super-element at joint #2 for party 'B' to do their own analysis.
Thank in advance for your advice.
Kasiphon
Kasiphon,
You can do it, but it takes some manual editing of the Utilities > Create Superelement runfile. You need to specify the SUBIN variable before your run SACWPRE (Preprocessor which uses the superelement input file to build the stiffness matrix):
SET SUBIN=subsef.deck.sample13 SACTIM SACWPRE STARTED AT IF NOT AVAR 1001 GOTO PREINPUTLOAD run ~sacsprog~SACWPRE < seaoci.test >> sublst.test :PREINPUTLOAD
You also need to specify that 1 superelement file is input and 1 superelement file is output. These options are located on the OPTIONS line:
You should get a superelement output file which includes the stiffness of the first superelement. I've attached a model which illustrates the difference for a jacket model with the deck superelement and without. The only two input changes are to the runfile and the SACS Option line.
SUB Input + Output.zip
If you need to use multiple superelements as input, you need to merge the superelements using the Utilities > Merge Superelement analysis type. Note that both superelements need to be connected to the 3 structure if you use this method (IE interface joints are connected to structure 3).
I will talk with the developers and see if we can add this to the Utilities > Create Superelement runfile to make this process easier.
Geoff
Thank you very much Geoff.
