Dear Sir,
I am curious about Stress Recovery option in Wave Response Module.
3 Methods i.e. Equivalent static, Enhanced Modal and Modal Acceleration method are mentioned in Wave response manual.
However, I do not see any option and command in SACS that able to choose one of those option.
Can you help to explain about this? How can we selected those option manually ? What is the defaults option in SACS?
Kasiphon
In the WVROPT line columns 19-20, you can select ES for the equivalent static option or EI for the enhanced modal acceleration method. I believe that the MR option is the modal acceleration method but I am not sure on that one because it has essentially been replaced by the equivalent static method and I haven't gotten many questions about it. I will have one of the developers look into it a bit deeper and get back to you.
Geoff
Hi Geoff,
Thank you for your response and still waiting for more info.
If it is possible, please help to elaborate more in the manual of next version.
