Dear all,
In some analysis i have the following warning.
*** WARNING-BENDING AND TORSIONAL SHEAR INTERACTION OVER LIMIT ! MEMBER J1,J2= ST01- V001 LOAD CASE= 6
Could you give me what is the criteria regarding that warning ?
NB : it usually happend on some rigid element (when i model as a rigid body equipment for instance) so i don't focus on it.
I believe that this is a limit set by the code check that you have selected, most likely a validity related check as opposed to a unity check. It looks like it is limited to the Norsok code check which I am not entirely familiar with so I can't tell you which section it relates to. If you would like to clear those messages for your rigid elements, you can try skipping the post-processor check by selecting the skip option for the member or group.
Geoff
