Hi everyone. I am a student trying to figure out how to create a hole in the middle of the cylinder for my school project. I tried many ways but the program wouldn't run. Please advice on my mistake.
&dimen -save -dimen meters m-tons&DESCRIBE body BUOYpgen B -perm 1.0 -loc 0 0 0 0 0 90 -diftype 3ddiffplane -7.00 -cart 4.0474 0 \ 4.0475 6.49plane 0.00 -cart 8.095 0 \ 8.095 6.49plane 7.00 -cart 4.0475 0 \ 4.0475 6.49end pgenpgen C -perm 0.0 -loc 0 0 0 0 -90 0 -diftype stripplane 0 6.49 -circ 0 0 1.82 0 5 72 end pgen
I want to make hole pgen C inside pgen B, please i need advice
Hello Auliya,
Can you tell me what the hole will be used for?
Thank you,
georgina
Hello Georgina
I want to make something like Single Point Mooring,
So i need to make hole in the middle of my hexagonal structure.
in real structure the hole will be used for riser and piping system.
can you tell me how to make a hole inside my hexagonal hull structure ?
Aldi
Hi Auliya,
for your purpose of SPM Buoy, Use Surface Command to define the Hexagon and the cylindrical hole,
Use DIFFERENCE to cut the hole from Hexagon and then EMIT the model to use.
Hitendra
You want the hole so that the mooring line can be attached? This is the hole to be used as a fairlead?
There is a sample in the default installation that shows how to model a single point mooring. Please see the sample files with root name "buoy". This is the location of the files.
C:\Program Files\Bentley\Engineering\MOSES CONNECT Edition V11\hdesk\runs\samples\mooring
The assumption is that the defaults were taken when you installed MOSES.
I hope this helps.
Georgina
Hi Hitendra,
i already using surface and difference command, but the model showed still same. and also error when i run into RAO analysis.
Could you please rewrite my model and make a magic for my model, so i can run into my software :D
thanks,
Aldi.
Kindly i attached RAO Command for my model
RAO.rar
