I have modelled curves and would like to extrude those curves. Once I try to do so and specify the vector (as 2,0,0; modelling in Body Plan; Extruding in Perspective) I receive the following error and it iterates once I click ok: Please set a non zero value
I am using Maxsurf modeller Connect Edition (Advanced) x64 (22.00.00.97).
Any ideas?
Are you sure you have 22.00 installed because the error message should be as follows (different from what you have shown):
can you send a screen shot including the "Extrude Surface" vector dialog as below - thanks
