ERROR - 113 NOT A RECOGNIZABLE LOAD CASE
Any body can help me to solve my fatigue running? I have check it many times, but I don't know what's wrong with my SACS file
  • Muhammad,
    It is hard to answer to your question without a better view of the whole analysis.
    However this error often occurs when the load case used has an input (in your fatigue input with FTCOMB card for instance) is the load label instead of the sacs basic load case.
    You can get the id of the loads you can solve a basic static analysis.
    In the listfile created search for "** SEASTATE BASIC LOAD CASE DESCRIPTIONS **",
     LOAD  LOAD     ********** DESCRIPTION ***********
     CASE  LABEL
       1      6     USER GENERATED LOADS
       2      9     USER GENERATED LOADS
       3     12     USER GENERATED LOADS
       4     1I     USER GENERATED LOADS
       5     21     USER GENERATED LOADS
       6     22     USER GENERATED LOADS
       7     24     USER GENERATED LOADS
       8     31     USER GENERATED LOADS
       9     32     USER GENERATED LOADS
      10     33     USER GENERATED LOADS
      11     34     USER GENERATED LOADS
      12     41     USER GENERATED LOADS
    In the list you can find the correspondace betwee the load case ( to be used in SACS fatigue input) and the load label (Created by user).
Reply
  • Muhammad,
     CASE  LABEL
