I can't open a project. I designed a boat based on background images, but now when I want to open it the whole program flashes with the message that the program does not respond. Maybe this is a problem with the photos, because I noticed that the program does not do too well with zooming in and out and regenerates the whole image again with the marked points, which is very annoying and time-consuming. Photos weight 5 mb and now I can't do anything. I can only send the model by e-mail due to copyrights and I have a video with this problem. Maxsurf takes a lot of ram whe this is "loading". Help me!
Hi Piotr,
I haven't heard of background images causing this sort of problem, but I suppose it is possible. If you move the images to a different folder or rename them, then MAXSURF won't be able to open them with the file (You'll get a warning dialog saying there is a problem)
If that doesn't fix it, you can submit a Service Request through connect.bentley.com to send your file through.
James
Thanks James for your response. Restarting computer was very helpful, but I have still some issues with this images. I have made the Service Request. I have these images in folder with a large number of files, so this is probably a problem. Thanks.
