Damping of SPAR floating structure using heave plate
Hi all, I really need some help with my undergraduate thesis. So, I've been analyzing the effects of heave plate in the keel of SPAR to motion response of the SPAR structure using MOSES, and experimental trials. so here is my question.
As far as I know, MOSES generates 6x6 full matrices damping and added mass in .ppo file that has 1/time unit for translational and m^2/s for rotational in its damping matrices. I've been using this to validate my experimental analysis result. from my decay tests in my experimental analysis, the value of B33 (heave damping) of my SPAR using heave plate is approximately 1536 KN/(m/s). But, from my MOSES analysis, I only got 241.626 KN/(m/s) for B33 (heave damping), I got this result from B33 component in the matrix damping times displacement of my SPAR (because the unit of .ppo matrix is the result from damping/mass). In my .dat file, I'm using -cs_current 1 1 1 command to calculate the damping of my SPAR. Am I using the wrong command? As before I used -tanaka and the result is lower.
thanks for the help
and here I also attach my .dat and .cif files that I used.
Spar.datSpar.dat
thanks for the help
Parents Reply Children
