I am a new user of SACS. Right now, I try to create Pile Superelements for mode shape extraction. I ran the Model file and PSI file with the PILSUP line, but I don't see the output file "dynsef". What might be the problem?
Thank You!
Ariel
you should set 'C' in column 10 in card OPTIONS in model input file (sacinp) as well.
whould you please explain where is it?
i use crat pile super element but its geneate a dynsef file that have weird text with 2kb size
is correct?
we can't tell whether there is a problem with your file only by size of the file.
Hi m-j , I wonder if have your problem solved , I am facing t he same problem with dynsef.
thanks
HI Remm
that file was correct because it is a file that we can not read it
