Is there any method to get the file of MSC.235(82), the additional criteria for offshore supply vessel that can be imported into Maxsurf criteria?
Thank you.
Benedict
Hi Benedict,
The criteria in MAXSURF Stability are all customizable, so you can definitely do this.
Copy and paste the criteria you need from the Parent Criteria into a new Group that you have created.
From the looks of it, the following parent criteria will be what you need.
Make sure that you are testing the Criterion for Damage cases.
James
Answer Verified By: Benedict Ee
