Good morining Sirs,
i would like to understand if it is possible to import a barge model (.dat file by Moses) into SACS Stability SW.
If it is possible could you explain me the porcedure to be followed?
Thanks in advance
Francesco
Georgina,
thanks for your prompt reply. The reason is simple: i have no Moses license but i received the barge imput file (.dat) for the barge i'm interested into and i would like to define the ballast plan (and ballasting sequence) by SACS stability.
I'm aware that the typical path is SACS -> Moses but for the reason above I was wondering if it is possible to import a .dat barge model into SAS Stability SW.
francesco
Hello Francesco,
SACS does not import in MOSES barge files.
Can you tell what company you are with?
Georgina
