I have been involved in fatigue run for multiple jacket connected each other at deck levels (i.e. one complex model).
The SACS files used for this project consists of skipped elements for one of the jacket structure within the complex. I have unskipped by selecting all elements in Precede for that jacket structure. Later, when I made fatigue run for joints, I could not get any fatigue results (all showing infinite).
However, when I run the analysis without unskip of elements, fatigue analysis is working fine.
Is it any issue in SACS? I am using latest version of 13.2.
Could anyone clarify? Thanks.
I am not sure what could be causing the problem. I don't see how unskipping elements would then produce results for the analysis. I'd suggest that you submit a service request and attach your analysis files so that one of our technical support staff can help you take a closer look at the results.
https://communities.bentley.com/products/electrical___instrumentation/w/electrical_and_instrumentation__wiki/40369/how-to-log-service-request
Geoff
