Hi Friends,
I am currently doing an analysis for cable installation, I try to model using the example j_laying.cif but the position of the roller is on the back of the barge, if for my case the roller is on the right side of the barge, my question is whether the position of the roller can be changed in the section right side of the barge?
Hello Affif,
I am interpreting your question as, "The sample shows the roller direction in the vessel x-direction. How do I change it to the vessel y-direction?"
The rollers have to be defined in the x-direction. You can redefine the vessel coordinate system so that the vessel x-axis is toward the port or starboard side.
Let me know if I understood you. Let me know if there are other questions.
Georgina Maldonado
Hi Georgina,
It would be greatly appreciated if you could explain more how to redefine the vessel coordinate system in MOSES. Could you give some examples of how do I change the roller direction in the vessel x-direction to the vessel y-direction?
Best regards,
Andy
Hi Andy,
You could try "&describe part pname -move". However, that only changes the part coordinate system. I would try that before redefining the entire model. But if the above suggestion does not work, you will have to redefine the model.
I hope this helps.
I'll do what you suggested.
Thank you.
