Hi everyone,need your advise on P-Delta analysis. We have run P-delta analysis, but it is stopped with error message Matrix Decomposition. We thought this related to member releases, we try then delete all member release and re-run, but error message matrix decomposition still remain. What possibility wrong with our model, please share your experience..Thanks
Hi Ivan,You can also look at the animated view of the structure. From there, you should be able to spot any abnormal fixity issues or non-connected members through this. I hope this will help. If it doesn't, please raise service ticket via https://apps.bentley.com/srmanager/ProductSupport and share your model so we can take a closer look on the error.
