*** WARNING: Element $BS0001 Is Being Redefined ???
Body X Y Z RX RY RZ
HOLMEN_P Location -0.00 0.00 -5.24 0.95 0.55 -0.00
N Force -124.47 -192.61 -0.01 31 0 -17523
Equilibrium Converged in 5 Iterations
Time To Generate Load Cases : CP= 0.42
Reducing Stiffness of DEFAULT
*** WARNING: Element $BS0003 Is Being Redefined
*** WARNING: Element $BS0004 Is Being Redefined
*** WARNING: Element $BS0006 Is Being Redefined
*** WARNING: Element $BS0008 Is Being Redefined
*** WARNING: Element $BS0011 Is Being Redefined
*** WARNING: Element $BS0013 Is Being Redefined
*** WARNING: Element $BS0016 Is Being Redefined
*** WARNING: Element $BS0018 Is Being Redefined
*** WARNING: Element $BS0021 Is Being Redefined
*** WARNING: Element $BS0023 Is Being Redefined
*** WARNING: Element $BS0026 Is Being Redefined
*** WARNING: Element $BS0028 Is Being Redefined
*** WARNING: Element $BS0031 Is Being Redefined
*** WARNING: Element $BS0033 Is Being Redefined
*** WARNING: Element $BS0036 Is Being Redefined
*** WARNING: Element $BS0038 Is Being Redefined
*** WARNING: Element $BS0041 Is Being Redefined
*** WARNING: Element $BS0043 Is Being Redefined
*** WARNING: Element $BS0046 Is Being Redefined
*** WARNING: Element $BS0048 Is Being Redefined
*** WARNING: Element $BS0049 Is Being Redefined
*** WARNING: Element $BS0051 Is Being Redefined
*** WARNING: Element $BS0053 Is Being Redefined
*** WARNING: Element $BS0056 Is Being Redefined
*** WARNING: Element $BS0058 Is Being Redefined
*** WARNING: Element $BS0059 Is Being Redefined
*** WARNING: Element $BS0061 Is Being Redefined
*** WARNING: Element $BS0063 Is Being Redefined
*** WARNING: Element $BS0066 Is Being Redefined
*** WARNING: Element $BS0068 Is Being Redefined
*** WARNING: Element $BS0071 Is Being Redefined
*** WARNING: Element $BS0073 Is Being Redefined
*** WARNING: Element $BS0076 Is Being Redefined
*** WARNING: Element $BS0078 Is Being Redefined
*** WARNING: Element $BS0081 Is Being Redefined
*** WARNING: Element $BS0083 Is Being Redefined
*** WARNING: Element $BS0086 Is Being Redefined
*** WARNING: Element $BS0088 Is Being Redefined
*** WARNING: Element $BS0091 Is Being Redefined
*** WARNING: Element $BS0093 Is Being Redefined
*** WARNING: Element $BS0096 Is Being Redefined
*** WARNING: Element $BS0098 Is Being Redefined
*** WARNING: Element $BS0101 Is Being Redefined
*** WARNING: Element $BS0103 Is Being Redefined
*** WARNING: Element $BS0106 Is Being Redefined
*** WARNING: Element $BS0108 Is Being Redefined
*** WARNING: Element $BS0111 Is Being Redefined
*** WARNING: Element $BS0113 Is Being Redefined
*** WARNING: Element $BS0116 Is Being Redefined
*** WARNING: Element $BS0118 Is Being Redefined
*** WARNING: Element $BS0121 Is Being Redefined
*** WARNING: Element $BS0123 Is Being Redefined
*** WARNING: Element $BS0126 Is Being Redefined
*** WARNING: Element $BS0128 Is Being Redefined
*** WARNING: Element $BS0131 Is Being Redefined
*** WARNING: Element $BS0133 Is Being Redefined
*** WARNING: Element $BS0136 Is Being Redefined
*** WARNING: Element $BS0138 Is Being Redefined
*** WARNING: Element $BS0141 Is Being Redefined
*** WARNING: Element $BS0143 Is Being Redefined
*** WARNING: Element $BS0145 Is Being Redefined
*** WARNING: Element $BS0146 Is Being Redefined
*** WARNING: Element $BS0148 Is Being Redefined
*** WARNING: Element $BS0151 Is Being Redefined
*** WARNING: Element $BS0153 Is Being Redefined
*** WARNING: Element $BS0156 Is Being Redefined
*** WARNING: Element $BS0158 Is Being Redefined
*** WARNING: Element $BS0161 Is Being Redefined
Time to Define Model Topology : CP= 0.91
Time to Complete Nodal Loads : CP= 0.43
Time to Define Stiffness Blocks : CP= 0.14
Time to Form Element Matricies : CP= 0.90
Time to Form Global Stiffness Matrix : CP= 0.20
Time to Form Global Load Matrix : CP= 0.02
*** WARNING: 4.6 Sig. Figures Lost At *JE020 In Direction RY
*** WARNING: 3.8 Sig. Figures Lost At *BS0161 In Direction Z
