I have run the hydrodynamic for ship-shaped model and extracted the mean drift force. I found the mean drift force response for example,
translational "surge" is changing over the period of time.
as you can see below, from
period 30 sec - 18 sec. the sign convention is positive
period 17.5 sec - 10 sec. the sign convention is negative
Note:
I tried rerun with Moses old version i.e. 7.03 and get the consistent sign convention for a period of 10sec - 30 sec.
+++ M E A N D R I F T F O R C E S F O R A B C +++ =================================================================== Drift Name = OPERATIO Heading = 0.00 Computed Force Factor = 1.0000 Radiation Factor = 1.0000 Coriolis Factor = 1.00 Process is DEFAULT: Units Are Degrees, Meters, and M-Tons Unless Specified Mean Drift Force ( With No Force Factor ) / (Wave Amplitude)**2 Reported in the Body System E N C O U N T E R T R A N S L A T I O N R O T A T I O N -------------------- /-----------------------------/ /-----------------------------/ Frequency Period Surge Sway Heave Roll Pitch Yaw 0.2094 30.000 5.3 0.1 1.5 -0.9 -1582.2 8.7 0.2167 29.000 5.4 -15.0 0.3 181.1 -1500.0 -1618.0 0.2244 28.000 6.2 -18.4 -0.4 201.3 -1451.6 -1980.7 0.2327 27.000 7.1 -22.8 -0.9 224.9 -1409.6 -2456.1 0.2417 26.000 8.1 -27.7 -1.6 246.8 -1360.5 -2977.1 0.2513 25.000 9.3 -35.0 -2.2 276.8 -1323.3 -3759.0 0.2618 24.000 10.6 -44.0 -2.8 305.5 -1271.6 -4700.5 0.2732 23.000 11.8 -62.5 -3.4 379.4 -1244.0 -6652.0 0.2856 22.000 12.9 -46.4 -5.7 199.4 -963.3 -4957.2 0.2992 21.000 13.4 -31.9 -7.2 10.3 -745.9 -3550.4 0.3142 20.000 12.6 -5.5 -7.5 -250.7 -580.0 -1054.4 0.3222 19.500 11.5 8.2 -6.8 -369.9 -556.7 184.6 0.3307 19.000 9.8 21.2 -5.8 -470.3 -559.5 1303.7 0.3396 18.500 7.3 25.3 -3.8 -502.1 -678.7 1590.7 0.3491 18.000 3.8 26.0 -1.7 -504.3 -814.9 1550.1 0.3590 17.500 -0.7 22.3 0.4 -474.9 -979.8 1120.8 0.3696 17.000 -6.2 16.9 2.5 -428.7 -1158.4 565.2 0.3808 16.500 -12.8 11.5 4.4 -370.7 -1354.5 45.4 0.3927 16.000 -20.3 6.6 6.1 -301.8 -1583.0 -378.6 0.4054 15.500 -28.3 3.2 7.5 -225.0 -1845.0 -597.7 0.4189 15.000 -35.9 1.2 8.7 -144.3 -2153.6 -629.4 0.4333 14.500 -42.2 0.8 9.5 -68.0 -2500.0 -474.2 0.4488 14.000 -45.8 1.6 9.8 -7.9 -2866.6 -198.4 0.4654 13.500 -45.5 3.2 9.6 22.5 -3215.0 90.2 0.4833 13.000 -40.5 4.6 9.0 11.4 -3482.0 258.8 0.5027 12.500 -31.8 5.0 8.0 -47.4 -3587.2 204.2 0.5236 12.000 -22.6 4.0 7.0 -152.2 -3461.7 -48.9 0.5464 11.500 -18.0 2.4 5.8 -287.0 -3101.6 -253.1 0.5712 11.000 -20.8 2.5 4.3 -407.7 -2612.0 -16.1 0.5984 10.500 -25.2 5.7 2.0 -432.7 -2155.3 763.4 0.6283 10.000 -19.1 9.0 -0.5 -284.4 -1830.4 1324.5
Hello Haydar,
The current version of MOSES is Revision 11.02. I can help you with that version.
If you have the same problem with Revision 11.02 please let us know.
Georgina Maldonado
Georgina,
At the moment we only have version 07.10.00.17. However, could you please help test run using the latest version I would like to see the output. But, how can I share this file with you personally?
Hi Haydar,
Please send me an email to georgina.maldonado@bentley.com.
We can discuss this via email.
