Hello
Suddenly my Maxsurf modeler was show me a dialog box and tell me that dump file was created and stopped its job. How can I backup my work? Help me please.
depending on the version you were using their should be a temp file left which gets saved every few minutes. In the latest version the temp file is found in the %temp% folder:
for older versions of the software the file is normally to be found in the same folder as the last model file you saved or opened and looks like this
hope this helps,
Pat
James Clarkson
Answer Verified By: Ocean Man
