Dear Bentley User Support and Bentley Communities,
Does MOSES possible to generate the Moment to Change Trim (MCT) per 1 CM instead 0.01 DEG (<1 CM) in MOSES at page Hydrostatic Coefficients?
Note that, I am using the licenses MOSES version 11.
Figure 1. Capture Hydrostatic from Stability Booklet
Figure 2. Capture Hydrostatic from MOSES v11
Please response.
Thank you.
Hi Jamhari,
There is not an option to change the units for the two columns indicated.
I will ask the developers to put this on their list of requests. At the moment the enhancements for the next releases (2020) have been agreed. This request will be for after those release. Adding this feature will take some time.
Thank you for your patience.
Georgina Maldonado
Thanks alot for the swift response Georgina.
Have a nice day!
