1) I import SACS structure models into MOSES using &emit -sacs.
After import density of steel changes from 7.85 to 7.69, and from 8.478 to 8.304.
I need to keep track of weight and COG during transport analysis.
Hi Manish,
Could you please check the unit in SACS? The unit of a density in SACS is expressed in a mass unit, tonne per unit volume; but in MOSES, it is in kn. If this is not the case of you, please let us know so that we take a close look at it.
Best regards,
Bitna
