Hi all,
I am a Naval architect, Currently Working on a Jackup Barge Stability. I usually work on Auto ship. Since Auto ship have restriction in working on different wind direction , we have been trying for an alternate method to over come this issue.This is the 1st time am working on Moses for stability. I have completed the Moses Model.My Hydro static Particulars and tank particulars are fairly matching with the existing Values provided in the existing booklet.
However, am not able to cross check the KN Values since, am not able to get the KN values of the Hull.
Query No.1
How to get KN values in Moses.
AS mentioned above , i have completed the modeling part.I have also prepared the CIF file. Refer Below.(also Attached my .DAT File for Hull Model)
&device -oecho no -pri device -g_def device &style output -lpi 9&title STABILITY$$************************************************************* read modelINMODELHSTATICS kg_allow -draft 2.4 \ -wind 100 50 \ -damage SWB1P \ -yaw 0 \ -i_gm 0.15 \ -i_ar_ratio 1.4 \ -i_dang_t1 0 \ -d_gm 0 \ -d_range 10 \ -d_dwt_t1 0 END&finish
Query No.2
How to get Wind Moment table for Various Wind Direction
NOUF.DAT
