I am now trying to use AISC-LRFD 15th for rolled section member code check and ISO 19902:2007 for tubular member code check (SACS V13.2).
As indicated in SACS manual (Post Module) section 6.1.1, need to add "CODE" under "OPTIONS" line and define "CODE IS 5L........................."
However, the given results for rolled section members are coded check by Euro Code.
But this is not happen for AISC-LRFD 13th and 14th edition.
Not sure I am wrong to define/input in input file, please advise.
Compare Result.xlsx
Any one encounter this problem? please..
This is a bug. The next release of SACS (14.3) will include a bug fix to this issue.
Geoff
