In Offshore Structures Detailing softwares I see Bocad and Tekla is famous, In the Bentley Solution can intergration between SACS( for A&D) and ProStructures for detailing?
Any one have experience in this structures, please add your advise!
Thank you so much.
You can create an Integrated Structural Modeler (ISM) repository in SACS which can then be referenced by ProStructures for detailing purposes. You can generate an ISM repository in SACS with File > ISM > Generate ISM Repository. Every installation of SACS comes with a copy of ISM which can be used to review/modify/update the file.
Geoff
Gents, I just wanted to use IMS and convert a SACS model to STAAD pro edition. I opened the sacs model and from the file menu chose the IMS>create Repository then create a new name > hit start but got this message " Could not find ISM installation" any advice appreciated.
