Dear MOSES Experts,
Just a quick question for about Stability Analysis using MOSES v11,
How to Generate Wind Area in MOSES Output as shown below?
Hi Jamahari,
This is not a standard MOSES report. The command &report can be used to create a custom report. It appears you are looking at a custom report.
You can find out more about the &report command in section VI.E Message Commands of the MOSES manual.
I hope this helps.
Georgina Maldonado
Dear jamhari, may i know if u solved this? Does moses automatically calculate the windage area if i model it with &desc part, pgen command? Setting my -cs_wind (Cd) value..I’m stuck because my stability since to failed when i model a superstructure with part and pgen but pass when i only input #area data.
