SACS PSI program
I am trying to use SACS PSI program for a single pile but i kept getting error so I started useding problem 2 of SACS manual as input but get totally different result & a singularity in matrix & warning despite manual out put does not indicate the program gives any of these errors. This is the input file and I get this error
 ** WARNING - SOIL SOL1 CONTAINS STRATA FOR WHICH API RP2A-WSD 21 Supp. 3 RECOMMENDS THE USE OF CPT-BASED METHODS
also this error
JOINT 101 AT DOF DX
*** ERROR-STIFFNESS MATRIX IS SINGULAR
INPUT FILE IS AS FOLLOW :
PLOPT ENUC
PLTRQ SD
PLGRUP
PLGRUP PL1 28.0 1.00 50.0 50.0
PLGRUP PL1 28.0 0.75 36.0 175.0
PILE
PILE 2 201 PL1 1.0 1.0 8.0 SOL1
SOIL ICP
SOIL AXIAL HEAD 8 SOL1 ICP
SOIL API AXL SLOC 0.001 20.0 SILT 1.0 50.0
SOIL API AXL SLOC 20.00 60.00 SNSL 1.0 100.0
SOIL API AXL SLOC 160.0 SLSN 1.0 40.0
SOIL API AXL SLOC 200.0 SAND 0.9 80.0
SOIL API AXL SLOC 228.0 CLOC 20.0 50.0
SOIL API AXL SLOC 260.0 CLUC 40.0 70.0
SOIL API AXL SLOC 300.0 CLAY 70.0 90.0
SOIL API AXL SLOC 400.0 ROCK 100.0 200.0 100.0
SOIL TORSION HEAD 1000.0SOL1 Y
SOIL LATERAL HEAD 6 28. SOL1 Y
SOIL API LAT SLOC SILTSA 20. 0.5 50.0 20.0
SOIL API LAT SLOC SNSLCA 20.0 1.0 60.0 60.0
SOIL API LAT SLOC SLSNSA 60.0 1.5 70.0 125.0
SOIL API LAT SLOC SANDSA 120.0 140.0 1.75 80.0 125.0
SOIL API LAT SLOC SANDSA 140.0 2.00 80.0 125.0
SOIL API LAT SLOC CLAYS 200.0 3.00 100.0 0.250 0.001
PLSTUB D1002 2.2802 0.01306 625.4
END
Any suggestion how to resolve this
  • The first message is just a warning indicating that the methods used to generate the P-Y or T_Z curves falls outside of the validity range and the CPT method is recommended instead. This will not cause the analysis to fail.
    The second error indicates that there is instability at the pile tip. I see a ‘Y’ option on the SOIL LATERAL HEAD line which I believe will modify the stiffness at the pile tip. I can’t say for sure because I can’t see exactly what column it’s in. Try changing that option to ‘N’ and see if you get the solution to converge.
    Geoff
  • Thanks Geoff
    Done that & still get the same warning and error re singularity. My main issue was why the example/sample problem two in SACS manual does not even run with the SPI SACS program. I had a different problem that I was solving using PSI. I kept getting errors which did not make sense and just to test PSI I run the sample problem hoping I can run that & then modify the file to run my problem. I both cases the program keep giving me errors.
    PLOPT ENUC
    PLTRQ SD
    PLGRUP
    PILE
    SOIL                                                         ICP
    END
    My original problem was a simple pile but I keep getting error in line 4 re format but do not know what is wrong
    PSIOPT   METC Y       EX                                  S3
    PLTRQ SD
    PLGRUP
    PLGRUP PL1          40.64   1.0              27.5     36.
    SOIL
    SOIL AXIAL   HEAD  2     2.039          SOL1                 ICP
    SOIL API AXL SLOC    8.0  20.0 SAND   1.O
    SOIL API AXL SLOC  20.00   36. CLAY   70.0       2.36
    PLSTUB   FD1002     10.0                100.0
    END
