Maxsurf equilibrium stability analysis
I'm trying to run an equilibrium stability analysis on a single surface .msd hull model that I have created, as soon as I do this a .dmp file is generated and the program closes.
Large angle and hydrostatic analysis both work fine.
The problem does not occur if I use one of the pre-defined "quickstart" hull models.
Any tips gratefully recieved
