Dear Sir/Mdm,I am having a huge issue and problem with using MOSES.Due to the lack of my understanding and poor memory, I am having difficulties in a few issues. I have successfully completed a model of a semisubmersible design in MOSES.The only issue and problem are that I do not know how to run a few test results. The following are the test that I have to run in MOSES:1) Motion Analysis in regular waves2) Motion Analysis in irregular waves3) Wind and current load calculations4) Mooring analysis in wind, waves and current both quasi-staticPlease do help me or reach out to me if you are able to help me. I really do need your support. I will be very grateful to the help and assistance that anyone is able to provide. Thank you very much
Hi Mohamed,
Training is not part of help via Bentley Communities.
There are many samples and tests that are installed with MOSES. Please see the files in the following directory. The directory name below assumes you took the defaults when you installed MOSES.
C:\Program Files\Bentley\Engineering\MOSES CONNECT Edition V12\hdesk\runs
I would suggest you look at the files in the sea_keep and the mooring directory.
You can contact me via email, georgina.maldonado@bentley.com. Please include your company name.
Thank you,
Georgina Maldonado
Hi Ms Georgina, I am not able to access into the C:\Program Files\Bentley\Engineering\MOSES CONNECT Edition V12\hdesk\runs.I am an undergrad student and it does not give me any access to enter into that. Is there an alternative to this?
mohamed.zip
I am not IT support for the school computer system. This is an issue you need to discuss with the school IT.
I have attached a zip file to this message. The zip file contains the two directories.
Please send the name of your school.
