When looking at my latest model, after applying render, there are gaps towards the bottom of the hull and overlapping above the sheerline. How can I resolve these issues.
JT
PS: Any news on my further question about the Calculation Window? No reply has been received.
It is hard to guess from a rendered image, but I suspect that the control point net is very skewed or possibly even twisted.
- Try turning on the parametrics Display | Contours | Parametrics, Do the parametric lines go where you expect the surface to go?
- Take a look at your control point net, does it have twists or overlaps?
It looks like you have a lot of control points around your forefoot. Take a look at the control point layout in the Yacht design quickstart model (File | Design Quickstart) for an example control point layout. Display | Net | Display Net
Sorry - I thought I had replied to your question about the Calculation window saying it was an obsolete feature, included only for backwards compatibility. Let me go and check.
James
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
Hi John,
I meant Calculations Sheet is obsolete in the same way that a horse and cart is obsolete. Nobody is stopping you from using a horse and cart, but you'll find its easier to get around on your bike or in a car.
I can't see your images, can you please try pasting them again?
On Friday, June 5, 2020, 6:28 am, James Clarkson <bounce-b3c8b869-342e-4162-b858-a098c94885ad@communities.bentley.com> wrote:
Update from Bentley Communities James Clarkson Hi John, I meant Calculations Sheet is obsolete in the same way that a horse and cart is obsolete. Nobody is stopping you from using a horse and cart, but you'll find its easier to get around on your bike or in a car. I can't see your images, can you please try pasting them again? James View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
