Dear Community,Can anyone give me any idea to model the rigid link in SACS?Thanks alotTran T.Tuan
Rigid links can be modeled using Offsets where an invisible rigid link is introduced between the end of the member and the connecting joint.
SACS also supports master/slave joint relationships with individually coupled degrees of freedom, although this isn't quite the same as rigid links since the rotational degrees of freedom are coupled such that the rotations will be identical.
Finally, you can model a rigid link just by using a very stiff member. You can modify the modulus of elasticity to effectively model a rigid element.
Geoff
Many thanks Geoff.I solved the problem with slave/master connections
