SACS Plate Panel Check with ABS Buckling Guide
I use SACS v14 and I would like to verify the deck of a vessel with the SACS Plate Panel Check. I would like to consider the code ABS Buckling Guide mainly, but I am insterested also in the other two available API Bulletin 2V and DNV-RP-C201.
The deck is an large horizontal plate with a series of stiffeners of different shape and size. I imagine that the "Plate Panel Check" considers the Effective Width of the portion of deck on top each stiffener.
My question is if there is a tutorial and/or examples to how correcly model the deck of the ship. Do the stiffeners have to be introduced in the definition of Plate Group or shall I draw the stiffeners as members and connect each joint with a plate element?
Thank you in advance for your support.
Parents Reply Children
