The following criteria encountered analysis problems:267(85) Ch2 - General Criteria: 2.3: Severe wind and rolling - Error with with one or more sub-criteria
Hi Ramadan,
For any criteria with a roll back angle, I would first make sure that you are testing a wide enough range of angles, especially into the negatives. Try -180 to 180 degrees to be sure.
Let me know if that doesn't fix it and we can try some other things.
James
Hello James,
Felipe from Chile here.
I have the same problem trying to run the severe wind criteria for a small 13.8 m. passenger boat, I have set all parameteres according to code but continues to drop me the same window abt analysis errors...
It seems that is not integrating the areas under the curve, because of wrong set limits for the integral (angles)..
Maybe Im puting wrong data in the criteria settings, ive tried everything and there is only errors... All the other criterias passes ok including passenger crowding and turn angle
Hello Felipe,
Please share your model - you don't have to do this publicly if your files are confidential. The process is explained here: How to Share MAXSURF/SACS Model Files on the Forum
We will look at your model and assist with the issue.
Aleksandra
Hello Aleksandra,
Please find attached file13.8 mt boat.zip
Thanks in advance... I think I already solved, due to Q2 has to be negative angle.. (equlibrium angle - roll back angle), but will be good if you can find the error im doing.
Felipe
