James,
I have returned on to the forum then. Firstly, I'm confused with your Calculations Window answer? Basically the function doesn't work and as previously described the User Manual from Page 76 doesn't make sense. I have not received a new instruction manual with your changes? Or I cannot down load.
Rendering Issue
Going back to my email. I have attached some screen shots from one of my designs. You spoke of the network which I think is displayed in the picture. Towards the bow there is a slight twist but nothing that should make the render spill above the sheer-line? An additional issue, when you look closely at the hull from the front, the hull surface appears like a hexagon shape. The amount of time I've wasted trying to straighten the hull when I probably didn't have too. When you include the shadows back on the model, the lines just appear rounded as I require. So my observation is the rendering issues must be a software problem? Your thoughts would be appreciated.
I have now worked out the rendering issues observed. It comes down to a setting within the display rendering window. The user must change the function to Setting 5. Why not Maxsurf have this as an automatic setting ?
JT
