Dear Sir,
I created curves using maker stations. However, I can't use the skin curve command it is not highlighted in the index. Can you tell me what is the reason for this
Sameera
Hi Sameera,
You need to select some curves first, then the Skin Curves command will be active.
If you're using the Skin Curves command, it will join together all of the start points of the curves along one edge, therefore curve direction is important.
If you find you are getting a twisted shaped surface, try using Curve | Reverse Curve on the problematic curves.
If you can't tell by looking, you can click on the last control point in a curve and see if it is Column 0 (the start) or a higher number (the end). In my case, I'm making sure that Column 2 is at the gunwhale for every curve.
James
Answer Verified By: Sameera Jayaratne
