hi
i am trying to run a static collpase analysis but getting the following error. please can someone advise how to overcome it ..thanks..
how to restore the default settings within analysis generator...so all the system files are read properly..
Hello,I can see from your screenshot, you are trying to run the analysis from your network drive (C:). The error indicates that you didn't have permission to write the file in that network drive. You can get the write permission from your IT administrator. Also, you can try copy the analysis folder and run the analysis in your local drive. I hope this helps!
You can restore the default settings within the analysis generator as below: 1. You may reset the Output ID for all your input, output and run file here.2. Reset the Analysis Subtype or Analysis Type - you can set your own run file by creating a new analysis type or subtype.3. Update your Current Working Directory so SACS will read and write your output and run files into the correct directory.I hope this helps!
