When i run the analysis, i found my xxx.ps file is saved automatically in "....MOSES 7.10 V8i\bin\win32" folder. Is there any permanent solution to resolved this problem, instead of using "&CHANNEL GRA_DEV -FILE C:\.....ps". ?
Hi Haydar,
Can you tell me the command that you issued to get a xxx.ps file? MOSES does not automatically make xxx.ps files. It makes xxx.eps files.
Georgina Maldonado
Hi Georgina,
I am using this;
&CHANNEL GRA_DEV -FILE MOORING.PS
However, i found this file is not saved in my current folder but it went to ".......Bentley\Engineering\MOSES 7.10 V8i\bin\win32". Could you please advise the setting on how to ensure this output file is automatically save to current folder. This happen when I installed the Moses to a New Laptop. Or is this due to installation phase?
Are you running version 7.10? The latest version is 11.03. This problem does not occur in version 11.03.
Please upgrade to the latest version.
