In Moses the HA pull is coming higher than the wire tension, is this a moses bug or am i doing something wrong? we have tried so many iterations it is coming right in many but still why the analysis provides result like this ?
Hi Manish,
You give me very little information to work with. What is HA? Can you describe the analysis?
Georgina Maldonado
mam it is a mooring analysis of a simple barge, the mooring pattern is mediterrenean mooring. HA is horrizontal anchor pull.
What checks did you do to make sure the mooring system was modeled correctly?
This is a catenary mooring system?
Did you check the geometry of the line? The command to check this is "&status dg_connect".
Did you check the material properties? The command for this is "&status cl_flex."
What report are you reviewing when you say "HA pull is coming higher than the wire tension"?
georgina
As you can see here for 135 incident, the HA pull is above the max tension, In actual how the anchor pull will be more than the tension?
HI Manish,
I would suspect the two tables are from different analysis. I see 534 and 600 for MOR_1. The number of peaks in the two tables are different.
